3 Point Screach!!!
/ 3 Point Screach!!! #1
blaze
Central Florida
Kubota B6100E with dreams of a B7500
Whenever I lift my implements, i.e., box blade or finish mower, a relatively loud screach can be heard. This only happens under load and primarily when RPM's are up. At idle the implements are lifted and I hear no screach. Additionally, the problem is made worse if I try to slowly lift the implement as opposed to jerking it up. Just changed the hydraulic fluid. No improvement. Any ideas?
Model B6100, about 1200hrs.
Sorry don't know what top and tilt is
/ 3 Point Screach!!! #4
If it only happens under load (weight or force on the 3ph), it could be the pressure relief valve unloading. Does it screech with a relatively light implement and no external forces on the implement?
After re-reading your post I'd definitely point to the relief valve. It may have lost it's pre-set relief setting (usually a spring load). Someone else will have to chime in on repair, or try your dealer /w3tcompact/icons/smile.gif
Sound is definitely coming from the control valve assy as evidenced by the craftsman flat blade stethescope. The manual shows an adjusting screw presumably to increase or decrease pressure on the spring. I will give that a try and see what happens.
Thanks to all who helped with the diagnosis.
Mike
/ 3 Point Screach!!! #6
Does it have any problem lifting the load? Does it just screech for a second and then stop when the implement reaches the desired height? Have you had the tractor long?
Brian
No trouble lifting a load. It only screaches for a second unless I try to ease the implement up, then it will screach continuously. I have had the tractor only for a couple of years. It has a long history of non farm use. i.e. moving boats around.
Mike
/ 3 Point Screach!!! #8
It is normal for it to screech a little. Normally as it is approaching the top of it's travel right before the lever kicks back to neutral. What kind of oil did you use when you changed the hyd. fluid? I am also assuming that your control valve is 3 position type. Sometimes I can't keep the old tractors straight.
Brian
2015 Ford Explorer AWD SUV (A64557)
2015 Ford Explorer...
2021 Redirective Crash Cushion Guardrail (A64556)
2021 Redirective...
Panorama Hay Rake (A66408)
Panorama Hay Rake...
John Deere 4020 Tractor w/ Loader (A66285)
John Deere 4020...
Aluminum Fifth Wheel Tripod (A65579)
Aluminum Fifth...
HORST RSW HEADER CART (A64278)
HORST RSW HEADER...
