Chipper 3 point mount chipper shreader
/ 3 point mount chipper shreader #1
Duckhunter
Central Arkansas
New Holland TC45D
Does anyone make a 3 point mount chipper shreader to dispose of limbs and leaves in mass quantities?
/ 3 point mount chipper shreader #3
Ken
here is a link to an Aussie site. Not much use to you but might be of some help.
Cheers
www.dieseltraders.com.au
<font color=blue>Neil from OZ.</font color=blue><P ID="edit"><FONT SIZE=-1>Edited by njrqs on 11/19/01 03:30 AM (server time).</FONT></P>
/ 3 point mount chipper shreader #4
Ken, I have a Bush Hog CS100P with the optional output blower chute. This is a serious machine. I bought mine used (almost new) for $2,200 and find it especially good at chipping and shredding cedar for mulch. If you ask me a specific question, I should be able to answer. I have been considering adding the vacuum attachment, but I think I can fabricate one pretty easily with a vacuum inlet I can mount to my FEL. WHOOOEEE! A TC45D powered Vacuum. /w3tcompact/icons/shocked.gif
JimI
/ 3 point mount chipper shreader #6
Duckhunter: I spent quite a bit of time researching PTO driven chippers a year or so ago and finally purchased a Valby Model 140 for use with my small tractor. It's a good unit and I'm satisfied with it. I wanted a rugged chipper (commercial quality) and my short list of possibilities included the following:
Bear Cat www.crary.com (not as rugged as the next three)
Danuser www.easternfarmmachinery.com
Patu www.brushchippers.com
Valby www.valbysales.com
These chippers are all capable of serious work and long service. The Chinese-built chipper sold by Bolton (www.boltonpowerequip.com) seemed like a lot of chipper for the money, but I guess I've been turned off by the poor quality of some of the Chinese-built tools and things I've seen. The Bush Hog (www.bushhog.com) chipper/shredder was impressive, but didn't have as large and heavy a disk as some of the others. I've heard good things about the Woods chipper as well (www.woodsonline.com); someone in one of the discussions voiced the opinion that Woods chippers are built by Bear Cat (Crary). There are many other chippers, including Chippit (www.entectradingltd.co.uk), Ram (www.rampower.com), Befco (www.sledmaine.com), Gravley (www.gravely.com), Vermeer (www.vermeer.com), Roberge (www.comsearch-can.com), KwikChip (www.fletcherstewart.co.uk), Dr. Chipper, Morbark, Goossen, Brush Bandit, Mighty Mac (made by Mackissic and sold by Northern Tool). Some of these are too big; some are too small. Trying to get information on these will make you dizzy after awhile. By the way, I haven't checked these sites in some time; undoubtedly some will be changed or nonexistent now. And, of course, you need to answer a basic question: Do you need just a chipper or do you need a chipper/shredder combination? Other considerations include: ability of your tractor to power a chipper, diameter/thickness/weight of chipper disk, number and size of blades, size of shaft, type and ruggedness of bearings, direct drive or belt-driven to increase speed, thickness of sheet metal in housing, location and size of feed chute, availability of fan to aid discharge, ruggedness of stand, availability of mechanical or hydraulic feed, ease of use, ease of maintenance, location of dealer, availability of parts. I've undoubtedly missed some key points here, but it gives you an idea of what to look for. Good chippers are expensive. If you are lucky enough to locate one in good repair, grab it!
I've done quite a bit of work with my Valby and the only problem with it is that it plugs up easily when I run through leaves, grass and vines--especially if they're damp. My Valby is direct drive and its disk turning at 540 rpm doesn't throw the material with sufficient force to enable the machine to purge itself consistently. Also, I don't have a mechanical or hydraulic drive, so I spend alot of time pushing branches into the chute. Surprisingly, my 18.5 hp tractor handles the chipper just fine. Chipping brush takes time, patience and motivation. The mulch is worth it's weight in gold, but it's amazing how small a pile you wind up with after chipping a huge brush pile. Good luck on your search.
Great Reply.. Thanks! I have a TC45D that should handle any one I pick. I will do some brush work but have a bigger problem with leaves, tons of them. I would consider the vac attachment. I went to the Bush Hog site and the link for Chipper Shreader is not active.
Thanks for the help... Why pay over $1000 for a Craftsman when I can back up to one that will REALLY do the job.
Thanks to everyone for your replies.
2006 CASE 430 SKID STEER (A65053)
2006 CASE 430 SKID...
2021 Wacker Neuson G25 Quiet Power 20kW Towable Generator (A64553)
2021 Wacker Neuson...
2007 FREIGHTLINER BUSINESS CLASS M2 SPREADER TRK (A64277)
2007 FREIGHTLINER...
275 Gallon Cage Tanks, Koser Safe, with 2" outlet (A62679)
275 Gallon Cage...
QLF Lick-tank (A66408)
2019 FORD F-550 SUPER DUTY (A65643)
2019 FORD F-550...
