3 point log splitter
/ 3 point log splitter #1
reeltime
East Freetown ma
2014 mahindra 3016 shuttle loader and backhoe with thumb
I have a 3016 with backhoe if I remove backhoe I can use the backhoe lines for the splitter right
I mean a 3 point log splitter
Sent from my iPhone using TractorByNet
/ 3 point log splitter #3
the tractor hydraulics don't put out enough flow to run the splitter efficiently. the splitters typically have an 11gpm pump while the 3016 has an output of 7.8.
it would run very slowly.
I used to run on my bx2200 with out a problem for years I think that had a 5.7 gpm pump interesting
I think that will just affect cycle time
/ 3 point log splitter #6
that's what i meant when i said it would run slowly. it would be much slower going in both directions. it will still generate the same splitting force but it will take longer to split and withdraw the wedge.
But I could use the lines for the backhoe right because I still have that splitter
I just burn about 2 cord a year I just have a small squirrel woodstove now I use pellets for my main heat the wood stove is in my den l just grew up burning wood so I still like to burn when I can
/ 3 point log splitter #10
No the 3016 bh runs off the tractor hydro.
/ 3 point log splitter #11
It WILL work, but you will fall asleep waiting on the ram! lol
SR
/ 3 point log splitter #12
When I remove the backhoe to put on the splitter, I use the rear remotes. The next time I split I will try the backhoe connections. As far as speed goes....I never have to wait with the Split Fire as it splits both ways. (Don't have to wait for the blade to return)
/ 3 point log splitter #13
How do you like it... would you buy it again if you had it to do over?
Considering one for the L3800
/ 3 point log splitter #14
I love my split fire also. I agree I'm never waiting on the spliter. how long have you had yours?
It takes 3 people to ensure little to no downtime. One to supply wood to the lift or table, one operate / manipulate the wood and splitter, one to clear and stack or bag the wood. With 2 people the splitter is idle probably 30% - 40% of the time especially splitting ash as it only takes about 4" of stroke most of the time. I found it takes ~ 10 minutes additional time to split and stack per 1/3 cord simultaneously as opposed to splitting into a pile. to stack from a pile to 1/3 cord takes me about 20-30 minutes depending on how far I have to move the wood.
I run my tractor at 1800-2000 rpm when spliting with 2 people it's plenty fast. although I believe my tractors max flow is 17.1 GPM at ~2700 rpm
/ 3 point log splitter #15
get the 4 way, and log lift it's an awesome table. you can easily fit 16" pieces next to one another on the table. if you cut to longer that 16" consider one of the larger lengths. the 24" is like 32.5-33" between the uprights so you can just barely fit 2 16" pieces on the splitter at the same time. If I could do it again I would go with a 28" model.
/ 3 point log splitter #16
that's a tremendous flow difference over the OP's and most people who post with the same question.
/ 3 point log splitter #17
I really like the splitter and have had it for two years...no regrets at all. Canadian made so with our dollar in the tank, chances are it would be a bargain for Americans.
/ 3 point log splitter #18
I sent an e-mail for more information...
This way my splitter can stay home and my brother will have the 3 point he wanted all along.
His Lopi stove is small... it works terrific... just have to be careful not to cut too big or wood won't fit.
They were thinking getting rid of it when they bought the home... insurance had all kinds of questions and was OK when the seller had a permit for it...
They also have all the oak anyone could want... so the family room is now the most popular place in the home every night... doesn't take much to really warm things up.
Can the 3 point be lowered to the ground to avoid extra lifting?
Mine works just fine off the tractors hydros
/ 3 point log splitter #20
Yes the 3pt can be lowered. but for $500 the log lift was more than worth it since it doubles as a table.
check out the video below
https://youtu.be/ZEdMFiQxvk0
New/Unused Leaf Blower (A61166)
New/Unused Leaf...
2022 Bobcat T66 R - Series Skid Steer (A61166)
2022 Bobcat T66 R...
2025 Pabreak 84in. Hydraulic Rotary Tiller Skid Steer Attachment (A61567)
2025 Pabreak 84in...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
Hercules Pesticide Applicator with Nozzle (A61568)
Hercules Pesticide...
2017 Ford F-150 Ext. Cab Pickup Truck (A60352)
2017 Ford F-150...
