3 point log splitter on my 2305 JD
   / 3 point log splitter on my 2305 JD #1
jwm7240
john deere 2305
i just bought a ramsplitter 16 ton 3 pt splitter,i have a JD 2305 tractor,right now i do not have the power beyond,can i run the splitter through the loader valve ports? will it cause any issues?
anyone make there own power beyond for the 2305?
thanks in advance,jason
   / 3 point log splitter on my 2305 JD #2
That is an open center valve at 5.3 GPM. If you put QDs on the curl or lift circuits, you can plug in there for the hyd flow, You will have to bungee the lever open on the FEL valve.
this wont hurt (overheat)the pump or loader control valve?
   / 3 point log splitter on my 2305 JD #4
It shouldn't, as a lot of of people are doing just that.
Update, the 5.2 GPM is total flow, the implement gets only 2.9. Not that fast, but will get the job done.
The other 2.3 GPM goes to steering.
Max pressure 1987 psi.
How large is the splitter cyl?
Bunker Rake (A59228)
Truck Mounted Carpet Cleaning Extraction Machine (A57454)
Truck Mounted...
2020 FORD F-150 XL CREW CAB TRUCK (A59823)
2020 FORD F-150 XL...
2022 FORD E350 BOX TRUCK (A58018)
2022 FORD E350 BOX...
2022 Horizon (A55973)
2010 Ford F550 Bucket Truck with Altec AT37G Boom (A56435)
2010 Ford F550...
