3 point log splitter on my 2305 JD
   / 3 point log splitter on my 2305 JD #1
jwm7240
john deere 2305
i just bought a ramsplitter 16 ton 3 pt splitter,i have a JD 2305 tractor,right now i do not have the power beyond,can i run the splitter through the loader valve ports? will it cause any issues?
anyone make there own power beyond for the 2305?
thanks in advance,jason
   / 3 point log splitter on my 2305 JD #2
That is an open center valve at 5.3 GPM. If you put QDs on the curl or lift circuits, you can plug in there for the hyd flow, You will have to bungee the lever open on the FEL valve.
this wont hurt (overheat)the pump or loader control valve?
   / 3 point log splitter on my 2305 JD #4
It shouldn't, as a lot of of people are doing just that.
Update, the 5.2 GPM is total flow, the implement gets only 2.9. Not that fast, but will get the job done.
The other 2.3 GPM goes to steering.
Max pressure 1987 psi.
How large is the splitter cyl?
*Selling at Royal Auction Tampa, FL Location* (A59230)
*Selling at Royal...
2011 MULTIQUIP LIGHT PLANT/ FUEL TANK TRAILER (A58214)
2011 MULTIQUIP...
2015 Kenworth T880 QMC 8060R 40 Ton Tri Axle Crane Truck (A60460)
2015 Kenworth T880...
5-6 YD BLUE LINE GRIZZLY SCREENER (A58214)
5-6 YD BLUE LINE...
2008 New Holland B110 MFWD Loader Backhoe (A57024)
2008 New Holland...
Towable Sprayer (A59228)
Towable Sprayer...
