3 point lift capacity
/ 3 point lift capacity #1
chupacabra
fort worth, texas
iseki 1300TX
Does anyone know how the manufacturers determine the lift capacity of the 3 point system? Do they just start lifting something and gauge at what point the safety release valve opens, or what? I can't find out.
/ 3 point lift capacity #2
I imagine they are all different on how they spec them.
I dont know for sure, but if I had to guess, I'd say that they DONT actually test them physically. Rather they probabally just use calculations based on the geometry of the hitch, system pressure, and lift cylinder size.:thumbsup:
/ 3 point lift capacity #3
During my engineering career I worked for 3 major agricultural and construction equipment manufacturers. We verified all technical specs before they were released by actual measurement. Realize that meant 1 machine minimum, not every machine off the line although depending on which of the 3 manufacturers all specs like hydraulic pressures, travel speed, etc., were verified on each machine before shipment. They did not all read the same - every relief setting, etc., has a tolerance.
FORD SUPER DUTY TAILGATE (A64281)
FORD SUPER DUTY...
2001 Pierce Tilt Crew Cab Pumper Fire Truck (A61573)
2001 Pierce Tilt...
2019 INTERNATIONAL LT625 6X4 T/A SLEEPER TRACTOR TRUCK (A59912)
2019 INTERNATIONAL...
(2) UNUSED 12-16.5 TIRES W/ 6 LUG RIMS (A64280)
(2) UNUSED 12-16.5...
2014 Kawasaki 70Z7 Articulated Wheel Loader (A61572)
2014 Kawasaki 70Z7...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
