3 Point lift capacity
/ 3 Point lift capacity #1
rccoyote
Cooke County, Texas
Yanmar 1820D
Does any one have any idea what the maximum lift capacity of the 3 point on an 1820D is? I was wandering if I could move a round bail of hay. I know this may be pushing it's limits ( or maybe exeding them?) and i'm sure i would have to subtract the weight of the carry all. I think the tractor can handle it (because of it's weight with the FEL) i'm just not sure what the rated lift weight is. thanks rccoyote
/ 3 Point lift capacity #2
I don't know the lift capacity but you are probably only limited by your tractor weight and mechanical hookups, (weakest point). On my YM2000, I have caught my box blade in a root a couple of times and when I tried to lift it the front of the tractor lifted instead with 220 # weights. You can lift a house with a very small hydraulic jack.
/ 3 Point lift capacity #3
I know of a man, that uses a YM 1700 in a lot where they sell the trailers to carry the tractors and other things. He told me, that they would lift just about anything you put on them. That he had lifted the tractor off the ground many times, when it weighed too much. So I think it would probably lift it, but would it hurt it? Maybe Len would know about what should be the max for it, to lift.
/ 3 Point lift capacity #4
The limiting factor on what the 3 point can pick up will probably be the weight on the front of the tractor. If you're trying to picking up more than the capacity of the hydraulics , I'd think the relief valve would release . 500 lb bale-------yes, 1000------------maybe,, 1500------------I doubt it.
/ 3 Point lift capacity #5
The YM226D is a similar size USA model. Per the service manual, 1168lbs at the lower link and 816lbs 24" back. This confirms what lens wrote.
PS, if the front tires are in the air, just steer with the brakes!
Dave
Thanks guys. I was really hoping it was around 1000 to 1200#'s. At least. Guess i'll try and see what happens. Rccoyote
2022 EZ-GO ELITE...
Quick Attach Backing Plate (A65579)
Quick Attach...
Salt Dog by Buyers Slide in Spreader Box 10' (A62679)
Salt Dog by Buyers...
2015 A and A Melters A-110 Towable Hot Rubber Melter (A64553)
2015 A and A...
New/Unused Landhonor No Till Seed Drill (A65583)
New/Unused...
New/Unused CFG Industrial NT18K Mini Excavator (A65579)
New/Unused CFG...
