3-Point Hitch 3 point lift capacity question....
   / 3 point lift capacity question.... #11
If you have doubts then buy the extra capacity. If you don't have doubts, then buy the one you like better, whichever it is. Likely the L3130 will be more expensive, but if you need capacity it is the easy choice.
   / 3 point lift capacity question.... #12
Motor, if your heart is set on a 6 ft hd brush hog, dont be afraid to look at the new kioti dk45s, much more powerful machine then either the ck30 or L3130 and youll probably get it about the same price as the L3130. Good luck.
   / 3 point lift capacity question.... #13
Big ain't better on a tractor.
Had a 45 (not a kioti) that would bogg with a 6 footer in heavy grass. could cut faster with a 5 foot . ground speed will more than make up for width.
NEW Wolverine Skid Steer Trencher (A59000)
NEW Wolverine Skid...
NEW Fork Extensions (A59000)
NEW Fork...
2019 CATERPILLAR 305E2 CR EXCAVATOR (A52709)
2019 CATERPILLAR...
2013 Peterbilt 367 QMC 7060S 35 Ton Tri Axle Crane Truck (A55973)
2013 Peterbilt 367...
2021 Kubota SVL75-2 Track Loader (A56435)
2021 Kubota...
1999 FREIGHTLINER FLATBED (A58214)
1999 FREIGHTLINER...
