3 Point Hitch Quick Change Adapter
/ 3 Point Hitch Quick Change Adapter #1
ChiefMasterSarg
Orange, Texas
Kubota L2800DT-R
I saw a 3 point hitch quick change adapter model number HF141101 at Northern tool. Anyone useing this adapter?? How does it work with a post hole auger??? It looks like it would be good for bush hog and box blade.
Thanks, BIG HELP!!! I like the Pats quick change hitch. /forums/images/graemlins/smile.gif
/ 3 Point Hitch Quick Change Adapter #4
None of the quick attach units work with a post hole digger. It must be removed to attach the digger.
chuck
The Pats looked like you would not have to remove. I guess you mean it puts the Post Hole digger off verticle with it installed. Thanks, I did not think about that being an issue. The Chief!!!!! /forums/images/graemlins/shocked.gif
/ 3 Point Hitch Quick Change Adapter #6
I believe he means the quick hitch like the Northern Tool one. Click Here
I did a search for the part # you posted above. It does not come up as a valid number. Here is a link to the number on their site. Click Here
/ 3 Point Hitch Quick Change Adapter #7
Yes, that is correct. All post hole diggers (PHD) I have seen use the top point of the three point hitch. Quick attach systems like the john deere imatch and others of that construction must be removed before attaching the PHD. I have not used the Pat's system but it does look like it could be used with the PHD. Sorry for the confusion.
chuck
UNUSED WOLVERINE 6' FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
2019 Kenworth T880 T/A Wet Kit Day Cab Truck Tractor (A61573)
2019 Kenworth T880...
2019 Chevrolet Tahoe SUV (A61574)
2019 Chevrolet...
KUBOTA SVL97-2 SKID STEER (A64279)
KUBOTA SVL97-2...
UNUSED IRANCH IRTPL 10000 LB TWO POST LIFT (A64281)
UNUSED IRANCH...
2016 John Deere 6155R (A64119)
2016 John Deere...
