3-Point Hitch 3-point hitch log skidder
   / 3-point hitch log skidder #11
Just for some options, I made two pieces that attach to the 3 point receiver hitch. I have not used it yet but the plan is very similar to what easygo is doing. I want to use the lower plate to pull with and also as a bumper incase I go down hill and the log starts to catch up with the tractor.
   / 3-point hitch log skidder #12
I like the plate especially that it is removable. I never had a problem with logs catching up with the tractor but if it is a questionable situation I lower the 3ph a little and it gives more drag. It is very useful tho when you drop off the logs. Sometimes I end up with one slightly stuck under the frame of the thing.
A plate or other piece down low would certainly prevent that.
I have not put something like that on mine yet as it doubles as a rear ballast holder and I want the ground clearance when it serves that function. Did I mention that I really like the fact that it is removable? Thanks for the idea.
   / 3-point hitch log skidder #13
HarleyScooter-
Wow - you've got 75% of a logging winch fabricated there. I like the rear blade and the build quality looks very nice.
-Jim
   / 3-point hitch log skidder #14
Thanks easygo & Baby Grand, I was thinking about mounting a winch in there also and changing the hook on the top piece to a cable pulley. So far I have been able to get to all the wood I have cut and load it with the grapple I made for the loader. It is really nice not to have to manually pick up those 24" to 30" diameter pieces and put them on the trailer anymore.
   / 3-point hitch log skidder #15
I saw that and it was pretty nifty...esp with real big monster logs. I use this simple rig and it does fine...on bigger trees I'll load up the FEL with a bucket of clay.
   / 3-point hitch log skidder #16
savageactor7
Do you always run without pins in the drawbar or do you crank the turnbuckles tight so they are not needed?
   / 3-point hitch log skidder #17
I have one of the Norwood Log Hogs from one of the previous posts and it works great for what I need I can skid some pretty darn big logs with my B3200.
[/IMG]
Hey, HarleyScooter, nice photos. Are you using the BH hydraulics for the top link cylinder and where did you tap in for the grapple hydraulics? Thanks, Rusty
   / 3-point hitch log skidder #19
Yes I tapped into where the backhoe would hook up and installed two valves. I ran hoses to the rear valves for the grapple.
   / 3-point hitch log skidder #20
Hey, HarleyScooter that looks like a great setup. What are the wider clevis attactment points on the bucket for. Thanks, Dan
DRAGON 500 BBL FRAC TANK (A58216)
DRAGON 500 BBL...
Aluminum Bear (A57454)
Hypertherm Powermax65 Plasma Cutter w/Cart, PIN 083266, S/N 65-067003 (A59076)
Hypertherm...
New/Unused CFG Industrial H12R Mini Excavator (A57453)
New/Unused CFG...
2016 Ram 4500 Wrecker/Snatch Truck, VIN # 3C7WRKAL4GG243467 (A57453)
2016 Ram 4500...
UNUSED JCT 72" HYD TILLER (A58376)
UNUSED JCT 72" HYD...
