3 point hitch loads
/ 3 point hitch loads #1
fiddlerkelly
kubota b2630
i have a kubota B 2630 model . I have never used a 3 point hitch on mine but was planning on building a box to use on the 3 point hitch for when cutting firewood . How much weight can a 3point hitch lift including a box I make for it .
/ 3 point hitch loads #2
Somewhere around a ton depending on how you have it loaded. On my 1710 I can haul about 3/4 cord of hardwood when it is under 20% moisture. Here is a photo of my "box". It is 48 x 64 at the base.
/ 3 point hitch loads #3
Search engines and owners manuals are your friends! A real quick online search turned up 2139 lbs at the ends of the arms, and 1676 lbs 24"out.
/ 3 point hitch loads #5
Also reveals that tractor weighs 1786lbs. So OP may want some front end weights if he loads a near ton on the 3 pth. Front end may get a tad light otherwise.
/ 3 point hitch loads #6
Cheap plan: Three Point Hitch Pallet Forks, pallet, fence around pallet.
Thanks everyone for responding , plan is box big enough for about 1/2 cord of spruce / junipter or dry spruce so I should be save with that. I have a loader bucket on front of tractor so should be ok with the counter weight .
Looked in the owners manuel and had trouble finding that answer, I thought that would be under 3 point hitch section .
/ 3 point hitch loads #9
Yeah, no way that tractor will carry a ton without front weights. Either the front tires are in the air or the box is in the air, but never both. :)
/ 3 point hitch loads #10
whooppss. Should have read down. Yes, with an FEL and possibly weight in the bucket you might pull it off. Or carry it off. :)
Yeah well I am getting wood so might as well put some in the loader bucket too .
(APPROX. 18) 27' 26G - 5V GALVALUME TIN PANELS (A63290)
(APPROX. 18) 27'...
2022 FAE UML/SSL-150 Sonic Mulch Head (A63116)
2022 FAE...
24" X 84" METAL SHELVES (A63745)
24" X 84" METAL...
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A58216)
2013 ORTEQ ENERGY...
2024 Load Trailer 20ft T/A Flatbed Equipment Trailer (A56859)
2024 Load Trailer...
EARTHWAY PRECISION FARDEN SEEDER W/ PLATES (A63745)
EARTHWAY PRECISION...
