3 Point Hitch Hoist
/ 3 Point Hitch Hoist #1
jjkane
Quakertown, Pa
2007 Jinma 284
This a hoist I made with parts in my shed. I used hitch pins to hold it together so I can disassemble it easily. Also the legs for the hitch are from my engine hoist and I can use them on it if I need to. If anyone is interested in how I built it I'd be glad to let you know. joe.kane@Bruker.com
Joe
/ 3 Point Hitch Hoist #4
Interesting build, what is your plan for this? If you adjust just your toplink out all the way how much more distance can you get from vertical? Would replacing your toplink with a hydraulic cylinder gain anything for the purposes you intend?
/ 3 Point Hitch Hoist #5
I think it's a quality build. My only observation is that when you lift something it will put a tremendous amount of tension on your top link. I think it would be better off with the top link attachment point higher up on the "masts".
/ 3 Point Hitch Hoist #6
To pick up a really heavy item, raising the FEL high enough for a stout cable to clear the ROPS when hooked between the bucket and the end of the frame could eliminate the danger of snapping the toplink. Might cause other problems though.:(
/ 3 Point Hitch Hoist #7
Nice job. I wonder if a fold down stand under the 3ph lift arms would lesson the stress on the top link. When you're done working on whatever needed lifting, simply fold them up out of the way (like outriggers on a back hoe) and then drive off. Roger
/ 3 Point Hitch Hoist #8
Sorry, I doubt it. It would mostly lessen the weight carried by the hitch arms and the rear wheels. Possibly a good way to anchor everything while the lifted load is the air, though.:thumbsup:
/ 3 Point Hitch Hoist #9
If you are not carrying or moving the heavy loads, just lifting, add a 3rd leg for a tripod.
Bruce
/ 3 Point Hitch Hoist #10
I'm curious about what your intended uses are for it. It doesn't appear to lift very high. Why not just use the loader to hoist things up?
/ 3 Point Hitch Hoist #11
I too am wondering about the intended use...it looks like the winch is in the way of any vertical lift...or if not in the way, it's a least in the swing zone. With the existing design, it could be mounted on the tractor side.
/ 3 Point Hitch Hoist #13
Looks like some good building there, but like the others....
1. small wheels under it like Ag Crane has on some of their models will help it out - you'll find the front gets real light, and the rear tires get real loaded down, without.
2. The top link looks like it will be overloaded with a real load on it.
3. I too worry about thw winch location, woulda been in a safer spot on the tractor side of the frame.
--->Paul
Paul
I would have liked to do that but it would get in the way of the top link.
Dean
The first thing I did with it was to pull a round cement footer out of the ground. It was just something I wanted to try and build with some stuff I had around the house. The only items I had to purchase was a pulley, hitch pins and the steel plates at the top of the hoist.
It's still a work in progress. One thing I am considering for lifting things is to have some kind of outriggers to keep the front of the tractor from being pulled up.
John
One project I was planning on was lifting logs up at one end and dragging them out of the woods.
Roger
That's a good idea, it would put most of the stress on the lift where I want it and not on the front end of the tractor.
/ 3 Point Hitch Hoist #19
jjkane said:
Dean
More power to ya friend. I have had lots of people ask me why I did something....Because I felt like it, and wanted to and because I can!! Good enough for me!!
Nice job!!
WHISPEREATT 25 GENERATOR (INOPERABLE) (A58214)
WHISPEREATT 25...
2016 Assembled Parts T800 Tri-Axle Dump Truck (A59230)
2016 Assembled...
Hydraulic Tilt Bucket Mini Skid Steer Attachment (A59228)
Hydraulic Tilt...
2008 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2008 INTERNATIONAL...
2015 CASE 621F WHEEL LOADER (A58214)
2015 CASE 621F...
UNUSED FUTURE XLA59 - 59" DRUM SPIKE LAWN AERATOR (A52706)
UNUSED FUTURE...
