3 point hitch grapple
/ 3 point hitch grapple #21
Lt220,
Just a little curious why you did not make it to close tighter on the trash and logs, etc. I believe I would have left out the bottom center brace, and let the grapple close down tighter.
Lt220,
I thought about that. I decided to go with the design for strength. If I was to build it again I would probably change several things but It works great as is. I have not had any trouble pulling limbs or logs with the design. I was using it on a tree job yesterday. One of the trees got up rooted because it was rotten. I used the grapple to finish digging up the root ball and hauling off the stump. The stump was over 36" across at the root ball.....this grapple is a hoss!
/ 3 point hitch grapple #23
Wow, that is a beast! Looks great, almost JD OEM!
Mod you might consider: Chop out the middle section I marked with red X's, & extend the verticals & horizontals so they meet, brace them with a cross-brace, & then the grapple should close down even on smaller stuff.
attachment.php
attachment.php
Thanks for the suggestions. I did consider this type of lay-out for the grapple when I was building it. I added the lower cross piece simply because I wanted a solid tooth bar to tightly bite down on a log for skidding. I do agree that an open type grapple would allow me to close more but I wanted the cross piece tooth bar. Also,my cylinder (10" x 2") is about at it's max for extending due to my attachment points. I would have to go with a larger cylinder if I re-designed it. I plan on (in the future) making an open type grapple for my FEL when I get one.
The pictures don't show if but I added a removable tooth bar that attaches to the forked frame. This tooth bar works very well with the lower cross piece tooth bar on the grapple. This allows a good bite on a log.
2006 MINI Cooper Convertible Coupe (A61574)
2006 MINI Cooper...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
2023 Deere 317G (A64119)
2023 Deere 317G...
Caterpillar 980H Wheel Loader Service and Parts Manuals (A63117)
Caterpillar 980H...
Challenger 65-85C Tractor Service Manual (A63117)
Challenger 65-85C...
2004 Chevrolet Tahoe 4x4 (MPV), VIN # 1GNEK13Z24R318274 (A61165)
2004 Chevrolet...
