3 point attachments for BX sub CUT
/ 3 point attachments for BX sub CUT #1
kcook
Platinum Member
MI
Cub Lawn Tractor
Who makes Post hole digger, rear blade and box blade for the BX tractors (new BX24). And what sizes for blades, box, and Post hole for tractor size?
Thanks
KC
/ 3 point attachments for BX sub CUT #2
Laand Pride for sure and probably Woods. They have web sites.
/ 3 point attachments for BX sub CUT #3
I use Cat 1 impliments, 5' blade, 4'box blade, 4' tiller, Post Hole Digger with 9" auger. TSC sells the King Kutter line of impliments and they also carry the KK XB line that they market toward the Sub Compacts but the same size impliments are smaller scale, but more money, go figure. I haven't seen a need to use anything but Cat 1 tools on my BX 2200.
Any one else?
/ 3 point attachments for BX sub CUT #5
Full cat 1 implements, with BX lift modifications. 4' box, 5' blade, 6' (modified) rake, 5' finish mower, 4' rotary cutter, 4' tiller, 6' (2 row) springtooth.
/ 3 point attachments for BX sub CUT #6
The BX has a "limited" Cat. 1 3ph. The pins and holes are the same size, but the arms are "limited" in that their max. spread at mid-height is 32" and less at top or bottom heights.
I have a full sized Greene phd from Northern Tool & Equip. that I can fit on the BX2200 if I put the U-bar on first at mid-lift height, then raise it to attach the rest of it. GearMore makes a very small phd that fits easily.
I have a 42" Gannon box blade, 36" Howse rear blade, 40" Heavy Duty GearMore rough cutter, 37" Muratori tiller. A 22 hp BX can take bigger than these, but I use these sizes due to my own very hard adobe soil and 9'+ tall weeds & sapplings I need to cut. I also have a little Leinbach carry all, Howse dirt scoop, Howse combo sub-soiler/middlebuster.
/ 3 point attachments for BX sub CUT #7
KC; I have a Woods landscape rake for my BX. It is part of their "Estate" series, designed for sub-compacts. My rake is 60", the same size as the back blade they offer. Woods also offers a 48" box blade. I recommend them highly. You will find these attachments are much easier to hook up compared to full Cat. I implements. They have a shorter profile, which is a help with ground clearance with the implement raised.
Will
/ 3 point attachments for BX sub CUT #8
Leinbach makes a model7200jr post hole digger that has worked well for me. 5' finish mower, 4'boxblade, 5' rake, and 4' lawnroller are my other bx attachments.
</font><font color="blue" class="small">( Leinbach makes a model7200jr post hole digger that has worked well for me. 5' finish mower, 4'boxblade, 5' rake, and 4' lawnroller are my other bx attachments. )</font>
Great photos!!!!
KC
/ 3 point attachments for BX sub CUT #10
What a stump?!! What kind of tree was that?
/ 3 point attachments for BX sub CUT #11
It was a douglas fir. It was a hard fought battle.
3144 (A63117)
3144 (A63117)
2012 Freightliner FLD120 Ambulance (A64556)
2012 Freightliner...
2018 GEHL RS5-19 GEN3 TELESCOPIC FORKLIFT (A65053)
2018 GEHL RS5-19...
2026 DEVELON DX27Z-7-US30 EXCAVATOR (A65053)
2026 DEVELON...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
2014 Freightliner 114SD T/A Dump Truck (A64556)
2014 Freightliner...
