2nd welding project
/ 2nd welding project #1
Underdog57
W Michigan
LS R4041H
Played with My Power Arc 300 mounting a grapple on my bucket, getting better! Let me have it guys!!!! :)
Everlast PowerArc 300
Hobart 1/8" 7018 135 Amps
Hobart 1/8" 6011 90 Amps
These 4 are 7018 single pass;
These 4 are 6011 root with 7018 cover;
/ 2nd welding project #2
I found with my PA 300 Lincoln's Excalibur 7018 wets out real nice.
I'm fairly new to this welding game, so take my advice with a grain of salt. When making long welds like that. Back step them, and skip around. This will help control the warpage. ;)
/ 2nd welding project #3
Looks like it won't fall off. That's how mine are, I've been a hobby project welder for over 40 years and very few of my welds look perfect. I did use the step weld method.
I hope you remembered to weld the nuts on before welding the angle to the bucket.
Yeah, there are no LWS close by so end up with whatever TSC has. I will get some Excalibur when I get a chance.
I didn't really need that long of a weld, but I need the practice. Thanks for the advice but if you have only been welding for about 3-5 weeks I might have more experiance than you....LOL. Ha....Ha. :laughing:
Yeah I did, but I had to double & triple check it. :laughing:
/ 2nd welding project #6
Here's what the Excalibur looks like run with my PA-300. Funny thing, my PA-200 really likes ESAB's Atom Arc 7018. But on the PA-300 it's a very dry / non flowing puddle.:confused3:
/ 2nd welding project #7
Here's the Atom Arc, see how dry the weld looks? :confused3:
Oh yeah, quite a difference, guess I better get some Excaliber. What brand of 6010 does your PA 300 like?
/ 2nd welding project #9
I have good luck with ESAB's 10P, and Lincoln's 5P-Plus 6010.
Thanks SA, I'll probably try the 5P-plus.
2015 Volkswagen Golf SportWagen Sedan (A61574)
2015 Volkswagen...
Dual Tailwheel Rhino 284 7ft Cutter 2.5in cut capacity (A63689)
Dual Tailwheel...
Wacker Neuson PT2 Water Pump (A59228)
Wacker Neuson PT2...
2017 Dodge Charger Sedan (A61574)
2017 Dodge Charger...
CASE INTERNATIONAL 2208 - 8R30" CORN HEAD (A63291)
CASE INTERNATIONAL...
1999 Sterling L9513 Tri-Axle Roll Off Truck (A59230)
1999 Sterling...
