293 hydrostatic transmission problem
/ 293 hydrostatic transmission problem #1
Mattech
Hi All
my tractor 293 hydrostatic loses power going forward up a hill and will bog out , when I back down the hill and the engine RPM`s come back up I can use the tractor on the flat surface going forward or back . I can back the tractor up the same hill with no problem it is just in forward motion going up a steep grade which I have never had this problem before. Has anyone else had this problem and what was the fix?
Would appreciate any help. Thanks JIM
/ 293 hydrostatic transmission problem #2
Check for water in your fuel filter bowl.. Has happened to me 2 times in that last year and a half.
/ 293 hydrostatic transmission problem #3
I agree with myyaz33. I had the same symptoms. Drained the tank, a new filter and fresh fuel and ran like champ. I also had to post here to figure it out.
Good luck hope this takes care of it for you.
/ 293 hydrostatic transmission problem #4
New fuel filter. Make sure the fuel cut off is to the left or right.
Hi all
The problem turned out to be the fuel gelled up from the severe cold added some 911 and all is good
Thanks for the help. JIM
/ 293 hydrostatic transmission problem #6
We always top off our fuel storage tank late in the fall after the local supplier has switched to the winter blend. This often eliminate the fuel gelling problem. If you use a storage tank you will want to put a can of the 911 in that also.
2016 Jeep Patriot 4X4 SUV (A64557)
2016 Jeep Patriot...
2017 Ford Explorer AWD SUV (A64557)
2017 Ford Explorer...
2022 JOHN DEERE 17G EXCAVATOR (A63276)
2022 JOHN DEERE...
JOHN DEERE QUICK HITCH (A64278)
JOHN DEERE QUICK...
2022 EZ-GO ELITE...
2022 EZ-GO ELITE...
