2920 owners
   / 2920 owners #1
cdcj
SE Arkansas
I am going to purchase a new Kubota in the next month. I had decided upon the 3200 until I stopped by another dealer that had the 2920 to test drive. I can say that the 2920 had less vibration than the 3200 but the 3200 did not have a frontend loader on it either. The vibration was not bad on the 3200 by any means.
For you guys cutting with your 2920, does it handle a good 5 ft bush hog like the Land Pride pretty well? I am going to be doing a little loader and dirt work, but after the first year or 2 i am going to be cutting grass and deer lanes about 80-90 % of the time. How does the 2920 do with 5 ft implements in general like a box blade, disk, etc.?
   / 2920 owners #3
I would say a 54" cutter would be max for the 2920. I have a 60" RFM and it runs it just fine, a 60" rear blade that from what little I have used it with my 2920 (its a new tractor) I think it will be just fine. But, I do not think I would want to tangle with a 60" box blade that was heavily engaged in the dirt. I also have a 48" tiller that works just fine, little narrow but putting out the $$ for a 4" wider tiller makes no sense right now. If you are looking at implements 60" or better you may be better off with a 3200 or 7800.
   / 2920 owners #4
I have the 2620, power is there, but it just doesn't seem to handle the 5' landpride rotary cutter I have. Only have use it maybe 5 to 7 times since buying it last year (cutter), I will be selling it as soon as I get time to take a picture of it and post it in craigslist. I believe a 4' would be much better for a rotary cutter. The finish mower works fine though.
2007 STERLING L9500 TANDEM AXLE DAY CAB (A52141)
2007 STERLING...
2018 KENWORTH T370 T/A DUMP TRUCK (A51406)
2018 KENWORTH T370...
2014 Ram 1500 Crew Cab Pickup Truck (A50323)
2014 Ram 1500 Crew...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2019 Ford F-150...
White 6065 Tractor (RIDE AND DRIVE) (A50774)
White 6065 Tractor...
HD Bin Dump Forks (A50120)
HD Bin Dump Forks...
