284 hydraulic pump problem?
/ 284 hydraulic pump problem? #1
Amez
BC,Canada
Jinma 284
Hi all
Today my loader and 3 point arms stopped raising at low RPM. I can still raise them when I increase the RPM. I assume the pump is not producing enough pressure.
Hydraulic reservoir is full , no obvious leaks.
My first guess would be a blown seal somewhere in the hydraulic pump.
I haven't done any troubleshooting yet but has anyone had this problem before or have any tips?
2007 Jinma 284
Mike
/ 284 hydraulic pump problem? #2
First look for excessive bubbling or foam in the lift box, and then check the engine oil to see if the level is higher than expected.
//greg//
Greg
There is no foam in the lift box , engine oil is at normal level.
I recently ( 5 operating hour ago) replaced the Hydraulic oil and filter.
Mike
Does the hydraulic pump on the right side of the engine operate both the loader and the 3 point arms? If it does , I suspect the pump , because both are affected.
Is there a relief valve for the 3 point system?
/ 284 hydraulic pump problem? #6
There is a priority valve between the output of the pump and the input to the steering controller. They've been known to become obstructed. You may have too much fluid going to the steering, and not enough to the rest of the system - which in your case is both lift and loader. Disassembly/cleaning of the priority valve is not difficult.
//greg//
/ 284 hydraulic pump problem? #7
//greg//
/ 284 hydraulic pump problem? #8
Mike,
Please describe your hydraulic flow. For example on my 284, the flow goes from the Pump to the FEL valve and then to the Priority Valve.
Also do you have access to a pressure gauge? It is a good thing to have for many reasons including this one.
RonJ
Thanks Ron
When I turn the steering wheel , while lifting the 3 point (at low RPM) , the 3 point stops.
This makes me think that niether the steering or the 3 point is getting enough flow.
RonJ
My flow goes from the pump through the loader to a diverter valve which I believe sends required flow to the steering and the reainder to the 3 point.
I'm waiting for a gauge at the local parts store.
Mike
/ 284 hydraulic pump problem? #11
/ 284 hydraulic pump problem? #12
RonJ
Mike
Mike,
Since both the FEL and 3pt are acting up - and one is before and the other is after the diverter valve, it is probably the pump or the FEL valve pressure release adjustment. Since it is working, I would not do anything until you can get a pressure gauge installed to see what you really have.
RonJ
//greg//
Greg
I just removed and cleaned the priority valve. There were no obvious deposits in there , but when I reinstalled it the lift systems seem to work. I won't know if it is full force on the 3 point until I put my hoe or a gauge on.
Thanks for the info.
I assume that the priority valve was diverting flow to the reservoir at a lower pressure than it was meant to effectively bypassing the 3 point lift ?
Mike
/ 284 hydraulic pump problem? #14
Well, I'm thinking the other way around. The priority valve was stuck to where the majority flow was diverted to the steering sub-circuit, thereby starving the loader and the lift. Your later mention that turning the steering wheel made the other hydraulics move - pretty much confirms that. Appears the simple act of removal/reinstallation was enough to unstick whatever was stuck.
//greg//
Heavy Duty Booster Cables (A59230)
Heavy Duty Booster...
John Deere 12in Channel Tooth Bucket Excavator Attachment (A64194)
John Deere 12in...
2004 VOLVO  L50D WHEEL LOADER (A63569)
2004 VOLVO L50D...
APPROX. 2000 GALLON FUEL TANK (A63291)
APPROX. 2000...
2009 Landoll 435A 50ft. 43 Ton T/A Tilt Deck Equipment Trailer (A60460)
2009 Landoll 435A...
2004 International 4400 Single Axle Dump (A62613)
2004 International...
