273 HST drainplug issue
/ 273 HST drainplug issue #1
CDR
Bronze Member
Fingerlakes NY
TYM 273
The last Hydro fluid change was done by my now defunked dealership with out authorization, that's another story. Went to pull the drain plug to do a fluid and filter change and can't get the drain plug out. Started with a 12" crescent wrench and started to round off the corners, then I tried a 16" pipe wrench and it is just starting to twist the plug not remove it.
It appears to be a pipe plug, is it? standard thread? Is it Magnetic? It is so out of shape now I may try welding a large nut to it and getting a socket and breaker bar on it but I'm not real hopeful this will work.
Will it drain fully by pulling out the the filter screen.
Any suggestion would be greatly appreciated.
Thank You
/ 273 HST drainplug issue #2
Just pull the hose off the screen fitting and drain, then pull out and clean the screen.
Carryall 1700 4x4 (A61574)
Carryall 1700 4x4...
2022 Continental Belton Auger Tractor Attachment with Bits (A66734)
2022 Continental...
2024 Land Pride PFL3048 48in. Forks and Frame Skid Steer Attachment (A66734)
2024 Land Pride...
2015 Ford F-250 Ext. Cab Animal Control Service Truck (A66736)
2015 Ford F-250...
2007 FRAC TANK 500BBL WHEELED (A68842)
2007 FRAC TANK...
John Deere 700 H Dozer (A62679)
John Deere 700 H...
