273 flex
/ 273 flex #1
CDR
Bronze Member
Fingerlakes NY
TYM 273
I have always thought my 273 had way to much of what felt like frame flex. I had always kept the loader mount bolts tight and no signs of cracks there.
Today I found
the problem. The twelve bolts(6 each side) that mount the transaxle to the back of the frame seem to be bottoming out before tightening fully against the frame.
The tractor has 300 plus hrs all by me and as far as I know the bolts have never been out. Has anyone else had this problem. I think I will be taking the rear wheels off to get enough room to work and add a washer to the bolts.
/ 273 flex #2
There have been a few posts on the same issue. After tightening then a couple different times, I used some Loctite the last time at it has held them so far.
/ 273 flex
Thanks for the reply!!
My impact gun couldn't tighten the bolts any tighter or loosen them. I took a couple out to measure the hole depth compared to the length of the bolt. It took a old floor jack handle as a cheater on a breaker bar to get them out.
Holes were plenty deep enough compared to bolt length so I cleaned out the holes with brake cleaner and reinstalled using the cheater to get them tight.
The flex seems to be gone so I will monitor for a while and see how it goes.
2015 Freightliner M2 106 Ambulance (A66736)
2015 Freightliner...
2015 John Deere 350G Hydraulic Excavator (A64194)
2015 John Deere...
2002 Bombardier Evinrude 90HP Outboard Boat Motor. (A66738)
2002 Bombardier...
Unused 2023 Norden SQ90 Hydraulic Bale Squeeze Tractor Attachment (A66734)
Unused 2023 Norden...
2002 SUPERLINE DO20T242LP T/A 24FT TRAILER (A66091)
2002 SUPERLINE...
Unverferth Ripper Stripper (A64126)
Unverferth Ripper...
