2720 question
/ 2720 question #1
wooden
1992/318 & 2010/2720 deere
Question for anyone who has access to JDparts. I For some reason , because of where I live,I am not allowed to access the parts site, because I am in the Virgin Islands and there are no official dealers here. I need someone with acceess to look up part # lva803201 and find out if, and how many, they have in stock. I can only look up part numbers from here.
Thanks to anyone that can help!!
Wooden
/ 2720 question #2
Looks like they updated jdparts this weekend, you might want to try it again later. The site doesn't allow me to search other dealers.
/ 2720 question
Won't make any difference trying again later. I went round and round with the JD site people, and where I live is the problem. I am going to re register using my sisters address in Virginia to see if that helps, meanwhile all I need is for someone to tell me if they have the part in stock at JD and how many if possible. This is a factory defect so they sold all that they had. Seems I am not alone with this problem.
Wooden
/ 2720 question #4
Hi Wooden,
You have to go through a JD dealer,or someone who deals in JD parts. When I check on a JD part through the JD parts website,it is through the dealer I chose to deal with when I set up the site.
You can also check part numbers with the online JD dealers.
It is a high pressure pipe,correct?
Price is 310.00 US dollars.
My dealer,along with a few others,show "no stock".
Greg
/ 2720 question
WOOWWW!!!!! $310 for a piece of tubing with two end fittings welded on to it??? that tube is no more than 3/8"X 5feet !! OK lets say it's the special bends in it then!! Had it not split right in the bend I would be using a piece of high pressure hose with the two end fittings and hose clamps. My dealer will be paying for it but I can see what I am in for down the road!!
Thanks for the info Greg!!You're a good man
Wooden
/ 2720 question #6
Wooden
If it's a factory defect, it should be covered by warranty.
/ 2720 question
The only way I see it is as a factory defect. What else could cause this line to split like it did on a brand spanking new 2720? This pipe is not in a location where it could be bumped by outside objects, Its broken under the seat at the bend where the banjo fitting is attached to the selective valve.
Wooden
/ 2720 question
As soon as this is resolved I will post the result. I have been without my machine for more than a month now and no one can tell me when JD will get this part. That's why I asked for help looking on the site to know when they get the new parts in. Maybe you can check in on it for me every few days since I can't access the site. would be a big help !!
Wooden
/ 2720 question #10
Can you get back up and running if you have a rubber line made up?
Looks like banjo fittings so probably can not substitute with rubber. I checked in jd parts and there is none available at any of my local dealers. Wonder if you can get one custom made.
Ever get over to Jost Van Dyke and Sydney’s Peace and Love?
/ 2720 question
Ever get over to Jost Van Dyke and Sydney痴 Peace and Love?[/QUOTE]
Have not been to Jost in years!! have not done too much sailboat racing in a while so its kinda pointless unless you just want to get really drunk at the regatta and sleep it off on the beach!! Pretty dead there in off season.
Thanks for the part look up for me. Will be calling my dealer today for answers again, and may run into a stone wall as usual. but I will be in touch for another look up in a few days. You been a big help!
KUBOTA RTV900 SIDE BY SIDE (A63291)
KUBOTA RTV900 SIDE...
1207 (A64280)
1207 (A64280)
GUN CART FOR TRAVELER (A63291)
GUN CART FOR...
2021 BOBCAT T870 SKID STEER (A62129)
2021 BOBCAT T870...
2015 John Deere 8345R (A64119)
2015 John Deere...
2020 CASE TV450B SKID STEER (A64279)
2020 CASE TV450B...
