26x12x12 tire mount secret???
/ 26x12x12 tire mount secret??? #21
When I am trying to get tires to seat the beads I remove the valve core and then attach a clip on air chuck to the stem to be adding air to the tire while seating the bead.
/ 26x12x12 tire mount secret??? #22
I bought a used bead seater tank 4-5 years ago off FB Marketplace for $40, only thing wrong with it was the bent handle. The only reason the guy was selling it was to get a larger one for large truck tires.
The frustration and time it has saved me was well worth it, especially for the front tires on my lawn tractors. I've used it more times than I can remember although maybe only 5-6 times a year including neighbors & friends.
Even got a deal on a used rear tine tiller because the guy couldn't get the bead back on, on one tire. He dropped the price, so I paid him. Told him I'd be right back, had to get an air tank out of the truck. He told me he had an air compressor and had worked for 2-3 hours to get it mounted and gave up and why the reduced price. He looked puzzled when I came walking back with the bead seater tank. I asked him if he could rock it up on the other tire and said sure. I placed the snout on the rim and WHOOF..!!, bead was seated. He looked at me and said SOB..., I gotta' get me one of those and laughed. Money he knocked off the price of the tiller more than paid for the tank right there.
There are lots of youtube videos sealing with fluid. I have two more to do but this time I'll start fire from a safer distance.
Here's one, but not safe:
/ 26x12x12 tire mount secret??? #24
Ive seen, up close the ether/match deal. Works great but i wouldmt do it myself self. These tires have thick walls so they dont wanna flex out to the bead area easily. Too bad they are mounted already. I have gotten tires delivered. Bring them in to a warm house, then, I put a few 1 foot long 2x4's between the sidewalls on the tire. Keep that way for a few days. It helped train the sidewalls to stay spread so they land on the Bead area of the rim.
/ 26x12x12 tire mount secret??? #25
My son's camper trailer had a tire go flat and was significantly deformed because it sat flat for a long time. I tried the ratchet strap technique, but I could never get both sides of the beads to seat. I applied generous amounts of grease to the bead, and it both lubricated and sealed the area long enough to seat.
I've also done starting fluid which is more fun💥
/ 26x12x12 tire mount secret??? #27
And then when you put the tubes you pinch them with the tools and have to patch the tubes.
Yep, rookie mistake. Tube is installed, then slightly inflated to get it centered,then attention to detail is required when mounting the 2nd bead.
Yup, starting fluid makes it exciting to seal the beads.
Fuddy, would you kindly tell us where to bought the replacement tires?
Walmart on-line.
I hate doing that but best price & just did another mower. A few days ago I had Walmart install four Goodyear's on wife's Mustang, ordered from Walmart. Great price.
/ 26x12x12 tire mount secret??? #31
My trick for setting a bead is to take a bicycle inner tube and put in on the rim between the tire and rim. Inflate enough to make contact with the side of the rim and tire, and then start inflating the tire. A little tricky. Try not to pinch your fingers.
I've mainly done car tires, so I'm not certain about your tractor tire, but it can't be too bad.
I'm not sure about the size for a 12" rim. Bicycle tires are sized by the outer diameter. So a 16" tube might be close to fitting over your 12" rim.
2021 CAT 289D3 (A60462)
2021 CAT 289D3...
SD Launch SDLB25 (A53317)
SD Launch SDLB25...
2016 MACK CXU613 MID-ROOF SLEEPER (A58214)
2016 MACK CXU613...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
2006 JLG E400AJPN ELECTRIC BOOM LIFT (A60429)
2006 JLG E400AJPN...
2008 V.E. ENTERPRISES 130BBL VAC TRAILER (A58214)
2008 V.E...
