2640 JD alternator hook up
/ 2640 JD alternator hook up #1
TandRFarms
2640 John Deere
Can anyone tell me if this alternator is hooked up correctly. It is not giving me the correct voltage during the tractors operation.
/ 2640 JD alternator hook up #2
Can you be more specific as to the voltage?:confused:
Yes, with the current configuration, the alternator will only show an output of 13 volts max at full throttle. When the tractor is at idle, the meter shows a constant 12 volts. I noticed, when i touch the meter to the pin on the left or the silver guard at the bottom of the alternator, it shows a constant 13 volts and at full throttle 14 volts. I was told that this JD has a regulator that only allows the battery to charge when needed. I just got the tractor back from the shop from the alternator being repaired.
Year: 2007 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 77,977 Plate: Body Type: 4 (A61573)
Year: 2007 Make...
ALUMINUM CUTTING BOARD, (2) POLY CUTTING BOARDS (A64278)
ALUMINUM CUTTING...
2026 DEVELON DX27Z-7 EXCAVATOR (A65053)
2026 DEVELON...
Interstate 20ft Tilt-Deck T/A Flatbed Equipment Trailer (A64556)
Interstate 20ft...
1994 Trailmaster Aluminum T/A 407 Chemical Tanker Trailer (A64194)
1994 Trailmaster...
EZGO (A64557)
EZGO (A64557)
