2640 JD alternator hook up
/ 2640 JD alternator hook up #1
TandRFarms
2640 John Deere
Can anyone tell me if this alternator is hooked up correctly. It is not giving me the correct voltage during the tractors operation.
/ 2640 JD alternator hook up #2
Can you be more specific as to the voltage?:confused:
Yes, with the current configuration, the alternator will only show an output of 13 volts max at full throttle. When the tractor is at idle, the meter shows a constant 12 volts. I noticed, when i touch the meter to the pin on the left or the silver guard at the bottom of the alternator, it shows a constant 13 volts and at full throttle 14 volts. I was told that this JD has a regulator that only allows the battery to charge when needed. I just got the tractor back from the shop from the alternator being repaired.
2021 Scout 210 Dorado w S/A Boat Trailer (A61574)
2021 Scout 210...
PALLET FORK MOUNT SAFETY BASKET (A61572)
PALLET FORK MOUNT...
CLARK FORKLIFT (A63291)
CLARK FORKLIFT...
2000 FORD F-650 SUPER DUTY (A63569)
2000 FORD F-650...
HLA Attachments Loader Forks (A64119)
HLA Attachments...
2008 Ford F-550 4x4 Landscape Dump Truck with Lift Gate (A61568)
2008 Ford F-550...
