2640 hydraulics
/ 2640 hydraulics #1
deankindhart
Springfield, IL
2640 JD
my hydraulic fluid on my 2640 is always milky looking even after draining and refilling. what am I missing?
/ 2640 hydraulics #2
You have not removed all the water..
Did you flush with a cheap mix of diesel, alcohol, etc?
Did you take preventive steps to block out any water from getting into the hyd system?
/ 2640 hydraulics #3
Do you park your tractor outside? 2 common areas for moisture in hyd oil on those models is cracked shifter boots and plugged breather hole on hyd oil filler cap. It's very important to remove milky oil as the moisture causes accelerated deterioration of wet clutch & brake linings. Because some of the hyd components have no drain plugs removing water requires several fluid changes.
/ 2640 hydraulics
Thanks for the help. No tractor is never parked outside but it does have water in it. I will try to flush it out but do you have any suggestions on what the quickest and best way to flush it.
/ 2640 hydraulics #5
Remove the return line from the oil front oil reservoir back to the transmission. Keep adding new oil to the transmission and turning the steering wheel until clean oil flows.
/ 2640 hydraulics #7
2016 John Deere TX 4x2 Gator (A64912)
2016 John Deere TX...
2022 Mack Pinnacle T/A Day Cab Truck Tractor (A64556)
2022 Mack Pinnacle...
CATERPILLAR 259D SKID STEER (A64279)
CATERPILLAR 259D...
PORTA POTTY (A68842)
2010 ALLMAND MAXI-HEAT MH1000 HEATER TRAILER (A67714)
2010 ALLMAND...
2017 Toyota Tacoma 4x4 Crew Cab Pickup Truck (A66736)
2017 Toyota Tacoma...
