2615 Tie rod ends
/ 2615 Tie rod ends #1
Dside
Wny
Mahindra 2615
I have a 2007 Mahindra 2615 with 725hrs, I noticed the right front tie rod is going bad, any cross reference available for tie rod ends? Thanks you...
/ 2615 Tie rod ends #2
Tie rods ends are fairly standard- the taper is near universal so all you need is the thread type on the rod/rack end. I'd remove it and bring it into the auto parts store. They should be able to get you there.
To realign- lift both front tires and put a line on each tire. Measure distance when both lines face forward and again when both lines face rearward.
About 1/8" toe in will help with steering when you get the machine above about 40 mph.
/ 2615 Tie rod ends
Thank you,I'll give it a try.
/ 2615 Tie rod ends #4
A tractor going 40 MPH would be somewhat unusual wouldn't it? I wouldn't want to be on mine going that fast.
/ 2615 Tie rod ends #5
Yes that's sarcasm- just getting toe close is all that's needed on a tractor. That's why the tape measure and line on the tires is all you need.
/ 2615 Tie rod ends
I knew RNeumann was joking around. BTW, A 2615 couldn't go 40 mph with a sail in a windstorm.
