2615 brush guard
/ 2615 brush guard #1
buck12
Veteran Member
Mississippi
Kubota 5460HSTC
I just bought a used 2006 2615. It has a loader but no front brush guard. I called the local dealer and he said he could get me one for $175.00. My question is will the brush guard work with the loader? This is all new to me so excuse my ignorance.
/ 2615 brush guard #2
Yes, the brush guard will work with your loader. If you look at your front loader bracket you will see pre-drilled holes that the guard will bolt to. I have an 04 (which doesn't have the holes) and a friends 06 (like yours) has the holes. I don't have the brush guard but if I bought one I'd have to drill the holes to mount it. The guard will be almost vertical in mounting and won't stick out that far. Its designed to work with or without a loader. If you look at my attached pic you'll see I added a front weight bracket with weights. They stick out 10" in front of the loader bracket without any interference.
/ 2615 brush guard
Thanks for the reply. Yes, it does have the holes. I was only concerned that it may not work with the loader attached.
9008SFL (A64556)
9008SFL (A64556)
Asphalt Roller Tire (A68134)
Asphalt Roller...
2025 Pallet of Miscellaneous Duplex Polyester Webbing Slings (A66734)
2025 Pallet of...
UNKNOWN  TRIAXLE LOWBOY TRAILER (A67714)
UNKNOWN TRIAXLE...
2014 FORD F-150 (A67714)
2014 FORD F-150...
BOBCAT SKID STEER BUCKET (A64553)
BOBCAT SKID STEER...
