2555 john Deere
/ 2555 john Deere #1
NathanialBertges
wattsburg,Pa
986ih, 706ih, 04mccormick, 170 allis chalmer, 950 john deere, 2555 john deere
3pt an hydrulics along with steering are not working. I removed the suction screen and it was covered in what looked like big chunks of black sand. I put a new spin on filter on it along with the element filter. Still nothing. Any ideas ?
/ 2555 john Deere #2
The park brake pad on my 2355 came loose from the brake band. Then little pieces of brake material and the rivets they were attached to went through the transmission and onto every valve seat in the machine. Causing erratic steering control, loss of loader functions, ect.
Those little pieces... after they had been chewed up in the transmission, to me, resemble what you describe as black sand.
/ 2555 john Deere
What did you do to resolve the isseues caused by this?
/ 2555 john Deere #4
Sold it.
Honestly, I completely flushed the transmission, replaced the steering box and hydraulic pump... twice each. The last time was by Deere.
No amount of flushing seemed to matter, it constantly ate the hydraulic valve seats. I was so fed up at that point I sold it for less than it was worth.
As luck would have it, he has had trouble free service from it as far as I know.
/ 2555 john Deere #5
Remove hyd filter,put 5 gallon bucket under opening start engine and see if trans pump will pump oil and how many gpm's.
/ 2555 john Deere
Which filter? The spin on or the cartrige filter?
/ 2555 john Deere #7
Cartridge filter. Another thing you can try is install a hyd pump destroking screw and then manually destroke/engage pump to possibly clear debris from valve seating area. Do tractor have a FEL??
/ 2555 john Deere
Not sure what that is, what is the best way to flush the system?
Could you send diagrams an location to the valves. Thank you, this is greatly appreciated
/ 2555 john Deere
I'm not sure what FEL stands for.
In a previous response, hydraulic valve seats where mentioned. Where are those located.
/ 2555 john Deere #11
FEL=frt end loader. Valve I referred to is stroke control valve(parts key 26) depending on which hyd pump your tractor has 23CMC or 40CMC.
2006 Peterbilt C15 (A64127)
2006 Peterbilt C15...
2021 Takeuchi TL6R (A64126)
2021 Takeuchi TL6R...
2007 FREIGHTLINER CL120 6x4 T/A DAY CAB TRUCK TRACTOR (A59914)
2007 FREIGHTLINER...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2018 Ford F-150...
2005 Isuzu NQR 4 door box truck with folding gate (A63689)
2005 Isuzu NQR 4...
2015 Ford Explorer SUV (A64557)
2015 Ford Explorer...
