2550 Tires
/ 2550 Tires #1
mawnlower
I have read some of the other related posts on getting ag tires for my 2550 and still not sure of the right size. Will the carlisle super lugs 23x10.5 work with my rims? Thanks for any help
/ 2550 Tires
/ 2550 Tires #3
Welcome to TBN. My CC GT 2544 rear tires are 23x9.5x12,
which means the 23x10.5 will not fit on these rims. The 10.5 means the diameter of the rims, 23 means the height of the tire, & the 3rd number is the width of the tire 23x9.5x12
/ 2550 Tires #4
/ 2550 Tires #5
I had my dealer mount Carlisles AG's 23x10.5x12 on my rear rims. The third number is the wheel size, not the width of the tire. The 2500's use 12 inch rear wheels, 8s up front. I replaced my stock 10s and 6s rear/front respectively on my 2180. The 23x10.5x12s will fit your 2500. They work on mine, although, I do lose the 6th deck setting as they rub against the 42" deck I have.
/ 2550 Tires #6
/ 2550 Tires #7
My bad on tire size misread paper on sizing. Will be more careful with other inputs.
/ 2550 Tires #8
/ 2550 Tires
Your stock tires were the 23x9.5 x12 I just want be sure as I am probably gonna have to order them from the net. Thanks again
/ 2550 Tires
/ 2550 Tires #11
Yep, actually I have two sets of rears. I have the 23x9.5x12 turfs and then I have another set of wheels with AGs that are 23x10.5x12. I put the AGs on in the spring and fall when I pull heavy aerators and rollers. I prefer the cut with the turf tires as opposed to the AGs, as I cut my grass high and they tend to mat it down more.
/ 2550 Tires #12
2018 SKYJACK  SJ843TH (A67714)
2018 SKYJACK...
1991 American Pride APE2-6 Electric Cart (A66738)
1991 American...
1994 CHEVROLET GMT-400 EXTENDED CAB TRUCK (A65054)
1994 CHEVROLET...
2003 Bombardier Evinrude 75 Outboard Boat Motor. (A66738)
2003 Bombardier...
2017 Link-Belt 350X4 Hydraulic Excavator (A66734)
2017 Link-Belt...
(3) Springstar 6.00-16 Tires (A64912)
(3) Springstar...
