2544 deck raise problem
/ 2544 deck raise problem #1
reid
Has any one else broke the deck lift pins in the shaft connected to the handle. This is the second time I have had to take the tractor back to the dealer for this. The first time I think the pin just fell out. Thanks reid
/ 2544 deck raise problem #2
I've not had a problem after Spring/Summer/Fall with the deck, and Winter/Spring with the blade.
/ 2544 deck raise problem #3
Wow that is an odd one?!? Do you run your deck in full ground contact by chance? Just trying to reason out how this could be happening.
Joel
/ 2544 deck raise problem #4
I haven't broke the pin but have broke the "fingers" (piece of metal that has 5 or 6 fingers to set the height of the deck off the ground when you raise the deck). I usually break these during the wintertime when I plow snow and ram into something hard. I think I have to do this again before I start mowing again this year.
Joel there are some small mounds I run over that could possible bottom out the deck but it is not a hard hit or anything like that. what are you thinling? Reid
Year: 2007 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 77,977 Plate: Body Type: 4 (A61573)
Year: 2007 Make...
2008 WELLS CARGO 16 ENCLOSED T/A TRAILER (A65643)
2008 WELLS CARGO...
Case TV380 (A62177)
Case TV380 (A62177)
2014 Ford Transit Connect Handicap Van (A61573)
2014 Ford Transit...
(15) Polyethylene Road Bed Protection Pads (A60462)
(15) Polyethylene...
2022 Takeuchi TL12R2 (A60462)
2022 Takeuchi...
