2544 axle popping noise rear end
   / 2544 axle popping noise rear end
No leaks anywhere.
   / 2544 axle popping noise rear end #12
JTKub said:
The axle seals do chirp and squeak on my 2544 as the wheels rotate. If I wipe them down (from the outside) with a clean rag and slather some silicone grease around the axle/seal area, they will stay quite for a while. Other than noise, there's no trans oil leakage from the seals, binding, etc.
Joel
Use silicone spray. It will penetrate under the seal lip.
Well I got it back and everything is working again. The sensor on the seat had to be replaced and the axle where the wheel hub bolts on was a little rusty and they put some grease on it and it stopped. Weird....
   / 2544 axle popping noise rear end #14
Joel
So mine isn't the only one that makes a noise while riding along?! It sounds like a cross between something in the tires and a squeak. I was beginning to worry I had a bad axle or something. That makes me feel better....
2020 MACK PINNACLE (A58214)
2020 MACK PINNACLE...
2014 Ford Transit Connect Cargo Van (A54814)
2014 Ford Transit...
TANK MANIFOLD (A55745)
2015 Peterbilt 367 (A55973)
2015 Peterbilt 367...
Poly Fuel Tank with Electric Pump (A55851)
Poly Fuel Tank...
1605 (A57192)
1605 (A57192)
