2544 axle popping noise rear end
   / 2544 axle popping noise rear end
No leaks anywhere.
   / 2544 axle popping noise rear end #12
JTKub said:
The axle seals do chirp and squeak on my 2544 as the wheels rotate. If I wipe them down (from the outside) with a clean rag and slather some silicone grease around the axle/seal area, they will stay quite for a while. Other than noise, there's no trans oil leakage from the seals, binding, etc.
Joel
Use silicone spray. It will penetrate under the seal lip.
Well I got it back and everything is working again. The sensor on the seat had to be replaced and the axle where the wheel hub bolts on was a little rusty and they put some grease on it and it stopped. Weird....
   / 2544 axle popping noise rear end #14
Joel
So mine isn't the only one that makes a noise while riding along?! It sounds like a cross between something in the tires and a squeak. I was beginning to worry I had a bad axle or something. That makes me feel better....
2020 DRAGON ESP...
2013 Peterbilt 367 (A55973)
2013 Peterbilt 367...
Portable Restroom (A54865)
Portable Restroom...
Club Car Carryall 2 Electric Utility Cart (A55851)
Club Car Carryall...
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2019 ALLMAND BROS...
2018 PJ TRAILER 32FT GOOSENECK TRAILER (A55745)
2018 PJ TRAILER...
