2544 axle popping noise rear end
   / 2544 axle popping noise rear end
No leaks anywhere.
   / 2544 axle popping noise rear end #12
JTKub said:
The axle seals do chirp and squeak on my 2544 as the wheels rotate. If I wipe them down (from the outside) with a clean rag and slather some silicone grease around the axle/seal area, they will stay quite for a while. Other than noise, there's no trans oil leakage from the seals, binding, etc.
Joel
Use silicone spray. It will penetrate under the seal lip.
Well I got it back and everything is working again. The sensor on the seat had to be replaced and the axle where the wheel hub bolts on was a little rusty and they put some grease on it and it stopped. Weird....
   / 2544 axle popping noise rear end #14
Joel
So mine isn't the only one that makes a noise while riding along?! It sounds like a cross between something in the tires and a squeak. I was beginning to worry I had a bad axle or something. That makes me feel better....
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
JOHN DEERE 7210R TRACTOR (A54756)
JOHN DEERE 7210R...
8ft Flatbed Truck Body with Axle (A55851)
8ft Flatbed Truck...
2011 Ford F-150 Crew Cab Pickup Truck (A56858)
2011 Ford F-150...
Husqvarna Riding Mower (A56857)
Husqvarna Riding...
23091 (A55758)
23091 (A55758)
