2538 will not shift out of high range
   / 2538 will not shift out of high range #11
Ihave a 2017 2538 with 145 hrs , mine seems to have gotten much easier to shift ranges although i have never put it in high. would also like to see a pic if possible . love the tractor.
I don't think I can get a camera in there. It is all black too.
Look at the sub range shifter. There is a rod connected to it with a washer and an a cotter pin on the bottom. Follow that rod. It connects to a small lever on the side of the transmission, also with a pin and washer. When you move the sub range shifter, it actuates the other lever (bellcrank) to shift the ranges. There is a 12mm bolt next the the bellcrank. I backed it off 1.5 turns, and it relieves the tension. Then the lever would move. I hooked the rod back up, and was back in business! Greased it up good, now moves through the gears very smoothly.
   / 2538 will not shift out of high range #13
Guessing the rod you're talking about is part number 5 in this diagram and the bolt you backed off is part number 20 and the part you jiggled is part number 2?
Exactly! Thanks, I tried to find that diagram but couldn't.
To gain access to the bolt, I had to remove the pedal linkage and push it out of the way. The bolt is hidden behind it.
   / 2538 will not shift out of high range #15
Thanks for the graphic! Huge help for me.
Now, what's the best way to get at that area with a cabbed tractor? From Below?
   / 2538 will not shift out of high range #16
I loosened the 12mm bolt and lever is still stuck. What am I missing?
Are you trying to move the shifter with the tractor off? Make sure the tractor is running and not in a bind...
   / 2538 will not shift out of high range #18
Either way it won't move out of high gear.
   / 2538 will not shift out of high range #19
I don't know if this is still happening to you, it's happened to me quite frequently lately.
Here's the only trick I know that works every time. Go park the tractor, have some food and let it cool off. Then 30 minutes or so go back out and wiggle it around a bit.
I noticed it happens when I use High gear after hard work for a few hours and I am returning to my house driving down the highway. I'm wondering if something to do with the heat in the transfer box or whatever a tractor has is the issue. Letting it sit has fixed the issue 3 times now. Just an three hours ago for the latest one.
I wish I had an answer... I rarely use high gear anymore, moved to a very hilly place so it stays in low range most of the time.
CFG Industrail MX15RX (A53317)
CFG Industrail...
Hydraulic rail grinder (A56436)
Hydraulic rail...
2019 LOAD TRAIL 35+5 GOOSENECK TRAILER (A58216)
2019 LOAD TRAIL...
2014 International Derrick Digger Truck (A55973)
2014 International...
2023 WRANGLER 5500T ARTICULATED WHEEL LOADER (A58214)
2023 WRANGLER...
1686 (A58375)
1686 (A58375)
