2520 stalling
/ 2520 stalling #1
ckiii700
Has anyone else encountered this problem, my 2520 will shut off while it's running. It doesn't matter if I'm on it or its idling in neutral. I thought it was do to the hot weather this summer, but it is acting up again lately. I've been treating the fuel and thought it was the problem bfore. The dealer couldn't find anything wrong. Anybody have anu ideas?
/ 2520 stalling #2
Try to find patterns as to when it happens. Is it always cold when it happens? If so you may just need to increase your RPMs. Is your PTO always on or is it in gear? It could be the seat sensor or just that you're getting up off the seat. Does it only happen after it's been run for a while or only when it's just been started? Does it happen at some RPMs but not others? Is it only when certain implements are in use? Check the manual for recommended services, have you done them? Are any of your other functions a little off (for example, slow or jerky hydraulics)?
/ 2520 stalling #3
I'd be suspicious of one of your safety shutoffs. The one under the seat is probably the first one to check. Others had mentioned occasional problems with the fuel shutoff solenoid.
Ralph
/ 2520 stalling
there doesn't seem to be a pattern to when it shuts off. I have to let it sit for a while then it usuaslly starts up. Sometimes it come back other time it runs great.
/ 2520 stalling #5
Sounds like a possible electrical problem, which may be tough to track down. How often does it do it? Check all the fuses to make sure they are tight and are making good contact in the fuse holder. I wouldn't think a fuel problem would be happening on an occassional event.
You might consider putting a jumper wire across the seat saftey switch to eliminate that as the problem.
Sincerely, Dirt
/ 2520 stalling
I'll give it a try and see what happens. Thanks for the help.
/ 2520 stalling #7
Possible intermediate fuel starvation issue. I had a similar problem with debrin the the gas tank.
/ 2520 stalling #8
Hiya,
Sounds simple but it's often missed, fuel tank vent. Make sure the vent is open. Easy way to test is leave the filler cap loose and run it, if it stays running, you have found your issue, plugged vent.
My 2 cents,
Tom
/ 2520 stalling #9
Does it shut right off like you turned the key off or does it stumble and starve before it quits? If it stumbles I would check the fuel filter bowl to see if it's full of fuel.
I would start with the seat switch like previously posted
/ 2520 stalling #10
Take a look underneath. There is a connector that can become loose. I have had mine disconnected driving over brush. But, come to think of it, maybe that did not cause it to shut off, but just not start up. Oh well, never mind...
/ 2520 stalling #11
If it is not fuel check the fuse box for corrosion or loose fuses. I had a truck that did that and it was a fuel pump relay. Not sure if 2520 has a relay for the pump.
JOHN DEERE 300P EXCAVATOR (A65053)
JOHN DEERE 300P...
Hitachi EX 270 LC, Cab, 32" Track Pads, Grapple (A62679)
Hitachi EX 270 LC...
Delta BS100 Shopmaster Bandsaw (A64553)
Delta BS100...
2021 JOHN DEERE 844L WHEEL LOADER (A64279)
2021 JOHN DEERE...
2013 Ford Transit Connect Cargo Van (A66736)
2013 Ford Transit...
2014 Evinrude 2-G 225 HP Outboard Boat Motor (A66738)
2014 Evinrude 2-G...
