2510 50hr. Service
/ 2510 50hr. Service #21
The two "axle" plugs drain low places in the final drives and you should drain both of those. You need to drain at least the lowest centerline plug and I suspect you should drain both centerline plugs. Be sure to have sufficient containers on hand to catch all the old fluid. Don't get excited if you see small metal chips/flakes when you drain hydro oil the first time. Removing the rubber fill plug (at back of tractor) will really speed the draining and plugging it back in will slow the flow while changing containers. Throw a big piece of cardboard under the tractor so you can slide in and out quickly by sliding on the cardboard (vs concrete or dirt). The drain plugs have magnets to catch chips; clean them. The magnets also make it hard to get the threads started when you reinstall the plugs. Take care, don't rush, and don't get it cross-threaded.
/ 2510 50hr. Service #22
And don't over tighten the engine oil drain plugs in the pan either. They are just tapped into the aluminum of the pan. Tighten yes, but don't over tighten. I used the Mobilefluid 424 also.
/ 2510 50hr. Service #23
You need to pull all 4 of the drain plugs (painted red on my tractor) for the hydro trans and rear axle. I used a 24" chain wrench to get my filter off and even that wasn't easy! There wasn't a level plug on my front axle just the dipstick on the top right side. Don't forget to grease all the zerks for the brake linkage and such while you're under there! Have fun getting to know her and be safe!
/ 2510 50hr. Service #24
When draining the front axel's outer drain plugs, you may have to make a trough or gutter out of a piece of aluminum flashing to direct the flow of oil into your oil pan and not down the wheel, tire and on the floor.
/ 2510 50hr. Service #25
Cardboard can work too.
Great! Thanks gentlemen, the advice is much appreciated!
/ 2510 50hr. Service #27
I agree on tightening the drain plugs. The torque setting is in Inch Lbs (I didn't have a wrench that would set that low). I just did hand tight w/3/8 rachet. Don't lose the crush washers. I guess they should be replaced but I reused them.
I didn't change the fluid in my front axle. I checked the level. IIRC there is a dipstick in one of the two filler caps.
Got my service pretty much completed beginning of this week(still need to change front axle fluid). That bottom hydro filter was ridiculous! Went thru about 4 filter wrench/chain before I finally got it.
On a side note, I found a spot for a toolbox.
/ 2510 50hr. Service #33
I was going to upload pics of my tool box and chainsaw holder but it doesn't work
You need to make sure that the pix are under 1Meg in size.. anything larger will not work. Win 10 has a built in pix resizer, just right click on the pix and resize will appear. or the fast stone image resizer will work.
Request Rejected
/ 2510 50hr. Service #34
Nope. I resized them to under 1mb and still won't show up here. And I've uploaded photos before that were bigger.
I saw from a search others are having problems too. I've had this problem in the past too. I'm not that computer savy.
/ 2510 50hr. Service #35
let me try one.
Figure it out Buggs, I want to see them :)
/ 2510 50hr. Service #37
DSCN1437.JPG Tool box
DSCN1438.JPG Chain saw holder. I'm gonna paint it black. The electric saw is in there just for demonstration.
I got 3 led lights to mount to the ROPS; just making the mounts.
/ 2510 50hr. Service #39
I took off the bracket that hold the upper-link clip and the slow vehicle sign and used that bracket
New/Unused AGROTK 72in Quick Attach Brush Cutter (A65583)
New/Unused AGROTK...
2015 GMC 3500 HD 4x4 Crew Cab Pickup Truck (A64194)
2015 GMC 3500 HD...
6ft Kodiak Extra Heavy-Duty Rotary Cutter (A65579)
6ft Kodiak Extra...
2020 Komatsu PC210LC Hydraulic Excavator (A64553)
2020 Komatsu...
Dueling Tree (A65640)
2019 FORD F-350 SUPER DUTY (A65643)
2019 FORD F-350...
