2415 attachments
/ 2415 attachments #1
kh48
will my 2415 4wd gear be able to handle five foot attachments with no problem like tiller, scrape, bb bhog ect. thanks Ken
/ 2415 attachments #2
I have a 2015 and it pulls a 6' Rake just fine. I also have a 5' finish mower that doesn't bog it down so you 2415 should do the above easily.
I haven't used the attachments you mentioned but you should do just fine. The BB may be an issue if you plan on digging down deep.
/ 2415 attachments #3
I'm not sure you want to run a 5' Brush Hog on that tractor though.
Probably too big for cutting thick stuff and it may be too heavy for safe operation.
/ 2415 attachments #4
I have a 2015 gear and have had no problem with an offset 48" tiller. You have more HP, so I doubt it would be a problem.
As far as the brush cutter, I've used both the 4 foot and 5 foot. The 5 foot gets a little unweildy, and makes the front end really light. You have enough HP, but I'd add some weight to the front. (concrete blocks in the bucket)
/ 2415 attachments #5
I'll add that I wouldn't run a full size cutter as they are to heavy, they make shorter and lighter ones for compacts.
I'll agree that it depends on what you will be cutting
/ 2415 attachments #6
I don't have any first hand experience with the 2415... but I know that it weighs more and has more HP than my 18hp Kubota B7410. I pull a 5' cutter with my tractor and only have front weight brackets (no FEL) for counter balance and it does fine. My cutter is an old Bushhog brand and I would consider it "light duty" but I've never had any trouble.
Unused 2023 Land Pride RCF2060 5ft. Rotary Brush Cutter Tractor Attachment (A66734)
Unused 2023 Land...
2007 CAT 140H MOTOR GRADER (A67714)
2007 CAT 140H...
15-19.5 Tire and Wheel (A68134)
15-19.5 Tire and...
CAT 953C Cab (A68134)
3 ROLL TOOL CARTS (A67714)
3 ROLL TOOL CARTS...
2025 BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A66734)
2025 BrushFox...
