2415 attachments
/ 2415 attachments #1
kh48
will my 2415 4wd gear be able to handle five foot attachments with no problem like tiller, scrape, bb bhog ect. thanks Ken
/ 2415 attachments #2
I have a 2015 and it pulls a 6' Rake just fine. I also have a 5' finish mower that doesn't bog it down so you 2415 should do the above easily.
I haven't used the attachments you mentioned but you should do just fine. The BB may be an issue if you plan on digging down deep.
/ 2415 attachments #3
I'm not sure you want to run a 5' Brush Hog on that tractor though.
Probably too big for cutting thick stuff and it may be too heavy for safe operation.
/ 2415 attachments #4
I have a 2015 gear and have had no problem with an offset 48" tiller. You have more HP, so I doubt it would be a problem.
As far as the brush cutter, I've used both the 4 foot and 5 foot. The 5 foot gets a little unweildy, and makes the front end really light. You have enough HP, but I'd add some weight to the front. (concrete blocks in the bucket)
/ 2415 attachments #5
I'll add that I wouldn't run a full size cutter as they are to heavy, they make shorter and lighter ones for compacts.
I'll agree that it depends on what you will be cutting
/ 2415 attachments #6
I don't have any first hand experience with the 2415... but I know that it weighs more and has more HP than my 18hp Kubota B7410. I pull a 5' cutter with my tractor and only have front weight brackets (no FEL) for counter balance and it does fine. My cutter is an old Bushhog brand and I would consider it "light duty" but I've never had any trouble.
535 GAL WATER TANK (A68842)
535 GAL WATER TANK...
For Sale - Brush Hog - Woods RCC42 rotary cutter
For Sale - Brush...
2011 BRENNER TANK TRAILER (A67714)
2011 BRENNER TANK...
ALLMAND  MAXI-LITE II V (A67714)
ALLMAND MAXI-LITE...
2012 CHANDLER TRI AXLE SPD-18 WATER HEATING TRAILER (A67714)
2012 CHANDLER TRI...
GENERAC MOBILE PRODUCTS MLT6S LIGHT PLANT (A68842)
GENERAC MOBILE...
