2400QT loader mounting information
/ 2400QT loader mounting information #1
jmcgee
Statesboro
David Brown 990
Hi, I have a 2400qt loader I need to make mounts to fit my David Brown 990. It has a cross-tube for the rear mount. It seems the only thing holding this tube to the tractor are 2 U-bolts. Can any one confirm this? Thanks
From the diagrams on German bliss that is all that holds it, seems like a lot of weight for a couple of U-bolts even if they are 50 bucks each. Hopefully I will find one I can look at, I don't wanna hurt myself.:duh:
Well, I was not able to find one to look at, No one seems to have any idea what it mounts like, no pictures, nothing. So I finally just picked up some metal, 10ft of 1/2" x 5" for the sides. I am going to go by the "Messick's" Bracket Kit P/N 24H40340 (For Case/David Brown 990, 995, 1210) drawing the best I can. No idea of the accuracy or actual the measurements. I have measured my bolt holes, that will be the easy part. I am going to make the rear brackets a little different. download.png
So, I ordered the power beyond block, I do not know how this is supposed to work, think I wasted 200 bucks :(
So, Its all mounted, I simply tapped the camel hump for hydraulics, everything works great... except I have to pull the lever to curl the bucket for the three point lift to lift. :(
On the positive side, I do have a working loader.
110 GAL WATER TANK (A68842)
110 GAL WATER TANK...
2003 Chevrolet Kodiak C4500 Flatbed 503372 (A62613)
2003 Chevrolet...
Hot Tub (A64912)
Hot Tub (A64912)
2015 KUBOTA F3990 MOWER (A66091)
2015 KUBOTA F3990...
2022 JCB Fastrac 4220 217HP 4WD Agricultural Tractor (A66734)
2022 JCB Fastrac...
2016 Ford Escape SUV (A66738)
2016 Ford Escape...
