Tires 240 Tires
/ 240 Tires #1
Nala
Can someone translate my YM240 tire size? I have 13.6 - 16 turf tires on my tractor and they're badly cracked. I'd like to buy new/used tires but can't relate that size to anything I see on the net.
Thanks for any help.
/ 240 Tires #2
On my ym2000 same as your US.240 my Bridgestone lug Specials are 9.5/9-24
Carey
/ 240 Tires #3
That's the correct tire size according to the original YM240 sales brochure.
Hopefully somebody here, or perhaps a large ag tire distributor, can suggest a modern replacement that will fit your rims.
/ 240 Tires #5
Carey,
Yanmar-USA originally offered a choice between ag tires on 24" rims, vs turf tires on 16" rims. Nala needs replacements for 16" OEM turf tires that came on the tractor when it was new.
/ 240 Tires #6
We normally stock the 13.6-16 turf tire. We actually sold two already today. They are not cheap though.
/ 240 Tires #7
Yeah I seen that. My guess is the 13.6-16 probably are not easily available and was giving Steve at Spalding as a reference who would most likely know what Her options were. I'm sure he would being a US. supplied Dealer for 10yrs. I would think he has ran across it before.;)
Carey
/ 240 Tires #8
If they hold air there fine. If not, get tubes or new tubes put in them and run them till the tubes blow out of the tire from rubber loss. It will not hurt anything, after all that tractor tops out at what 12-14MPH.
/ 240 Tires #9
Clemsonfor is right. These aren't Turfs but the tires have been on my YM2000 for Yrs. with tubes in them. There are some pretty deep cracks. IMO typical VN. When I bought it I figured I would also be replaceing them. To the day I have not had to add any air to them yet. You can also cut and add a old Tube as a buffer to give you more protection at the cracks if need be.
Carey
/ 240 Tires #10
... after all that tractor tops out at what 12-14MPH.
8.58 mph when equipped with big tires. Maybe a third less than that, with these little turf tires.
Nala, Clemsonfor and Carey are right. Replace the tubes if needed to keep the air in them. Then run until the tubes are bulging through worn spots. Or at least until you see the fourth ply (4-ply tires) bare, exposed, abraded. It's pointless to replace them before then.
You probably have years of remaining life there.
/ 240 Tires #11
both my 1500 and YM14 are running their original tyres and all are cracking. the fronts on the 14 have flaps of rubber hanging off them but i will run them till they fall to bits as they have 2/3 of their tread remaining.would post some pics but the cameras dead and the spares didnt turn up before Chrissy :(
/ 240 Tires #12
The GT14 I just bought has cracks all over the AG treads as well, but as long as they hold air, they'll be used!
2001 FREIGHTLINER FLD120 T/A 6X4 DAY CAB (A69167)
2001 FREIGHTLINER...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2014 Jeep Grand Cherokee SUV (A66738)
2014 Jeep Grand...
Metal Eagle Weather Vane (A66738)
Metal Eagle...
x (A68191)
x (A68191)
2017 JLG G5- 18A TELEHANDLER (A59914)
2017 JLG G5- 18A...
