2320 vs. 2520 - worth the difference?
/ 2320 vs. 2520 - worth the difference? #21
What I really like on the Kubota specs in the turning circle is quoted with (differential) brakes, yet it is very difficult, verging on impossible to actually do this. Sorry this is just bad design/ergonomics and was one of the many dings which lead me to pick the Deere over the Kubota.
I guess for Kubota before HST, the clutch was on the left and the brake was on the right, so when HST came along they eliminated the clutch and did not relocate the brake because it had always been on the right and just jambed the treadle in front of it and called it a day without much thought for usability.
/ 2320 vs. 2520 - worth the difference? #22
I am in total agreement.^^^^^^^
/ 2320 vs. 2520 - worth the difference? #23
I was also looking at the 2305 or 2320 but found allot complaints of the rear PTO failing. Has JD redisigned the new units to prevent this? From what I've read, the repair is quite expensive.
/ 2320 vs. 2520 - worth the difference? #24
We got the 2320, I did not like the rear on the 2520, the narrow tractor frame, the 3PH problems (at the time) and a couple more issues that I cannot remember. Before I would have bought the 2520 I would have moved up to the 3000 series. It did seem to me that the 2520 was an after thought and put out there primarily for mowing, just an opinion. I like the 2320 but neither the 2320, 2520 or the 2720 is built near as good as the old 650 we traded but then again that's the way it is these days.
/ 2320 vs. 2520 - worth the difference? #25
I too went for the 2520 after initially considering the 2320. When I bought it this past May, it was hard to really judge the benefits, especially since I'd not owned a machine with a front end loader before. In the end, it was the considerations of the FEL that pushed me to the larger hydraulic capacity of the 2520, and the slightly larger and heavier machine. I don't regret it at all, plus things like the bigger alternator and larger tires were also worth it, in my opinion. If you are planning to use the FEL frequently, I think the 2520 has an edge.
/ 2320 vs. 2520 - worth the difference? #26
Has anyone done any discing or cultivating(just small implements obviously) with the 2320 or 2520 to give a comparison? I am contemplating which one to chose also and my dealer(who obviously wants to make as much money on me as possible) says I should for sure go to the 2520 for the discing.
/ 2320 vs. 2520 - worth the difference? #27
my 2520 works hard dragging the 5 foot box scraper, so If you are really looking to drag heavy impliments, I would look up to a 2720. The Hydro just robs so much power, and they are only small tractors. a ATV will pull a disk better, as a bigger atv has 60 HP, VS a 2520 having 26 HP.
/ 2320 vs. 2520 - worth the difference? #28
not necessarily heavy implements. The disc I am looking at is only 6 ft wide and I can lift one side of it and the cultivator is about the same.
/ 2320 vs. 2520 - worth the difference? #29
6 foot is large. I only had a 5 foot single row angled disk, but I had it set super aggressive and in loos dirt.
My 700cc ATV pulled it much easier and faster, and was nice because it had suspension. It was not a 3 point mount, just a hitch mount cheap unit.
/ 2320 vs. 2520 - worth the difference? #30
As a 2520 owner, here's my thoughts. I could argue that there should be an advantage for the 2520/2720 over the 2320 when dragging an implement. This difference comes from the weight, tire size, and the larger transmission shared by the 2520 and 2720. But I believe the extra horsepower of the 2720 offers no advantage in this area.
When I drag my 5 foot blade behind my 2520, in clay soil with the blade facing forward, I can stall the tractor if I drop the blade too aggressively. By "stall", I'm not talking about the engine, but the limits of what the pressure relief system in the transmission will let me do. It won't let me break the transmission, at least not easily. Basically, the engine has not run out of power before the hydraulics of the transmission start to bypass the pressure.
Since the 2520 and the 2720 have the same transmission, I'd expect the same limits on how far you can push it until it just won't pull any more. The extra horsepower of the 2720 would be most useful for PTO driven attachments. If you were looking at a tiller, I could argue for the 2720.
Maybe we need an organized tractor pull between all of them to really see what makes a difference.
/ 2320 vs. 2520 - worth the difference? #31
Now that is interesting. I think I had a similar issue with our 2320 and just shrugged it off as "what the heck was that all about". Tractor would not move forward and the tires would not spin, I had the tractor in 4WD and had excellent traction trying to load the front bucket from a pile of hard packed clay/soil with about 650 lbs of weight hanging off the back.
/ 2320 vs. 2520 - worth the difference? #32
Yep, that happens on my 2520 also. Kinda annoying when you are really trying to work it hard with the wheels.
/ 2320 vs. 2520 - worth the difference? #33
...... the pedals stick when depressed either direction and it's more than a little disconcerting to try to approach an obstacle or predict stopping by backing off the throttle, only to keep going at speed.......
My '10 BX2360 started doing this at 30 hours . I thought it wasn't
a BX##60 issue , and was annoyed/wondered if it was a Kubota SCUT
trait . Think I solved it by flushing out all the moly-grease on the
offending zerk with lithium grease . I reckon the remaining solids of
moly were filling the zerk-space and increasing the return time ..........
It's been OK for the 15 hours since I went mad with the lithium gun .
Without a doubt it's frightening to have to hit the brake when it keeps
going . Came within 2" of going straight in the pond ( 9' deep and the
front tires on that brown embankment ) and that was when I decided
to flush the zerk. Hope you didn't lose too much on the change of colour:thumbsup:
/ 2320 vs. 2520 - worth the difference? #34
I have the same problem and use molly grease on that fitting. I am going to give your suggestion a try. Thanks for the tip.
OrangeRidge - wow! What a spot! The drop-off that I nearly went down was an embankment also about 9' in grade difference. But, not nearly as attractive as your pond. Instead of getting wet or worse, drowning, I would have ended up in a nice big patch of poison ivy.
Caterpillar D6H Series 1 and 2 Dozer Service and Parts Manuals (A63117)
Caterpillar D6H...
MULTIQUIP  Whisperwatt 25 Pull Behind Generator (A62613)
MULTIQUIP...
2018 Ram 1500 Reefer Meal Delivery Truck (A61573)
2018 Ram 1500...
2018 F550 Bucket Truck (A63689)
2018 F550 Bucket...
BUSH HOG SBX72 - 72" BOX BLADE (A63291)
BUSH HOG SBX72 -...
2016 GENERAC MMG025IF4-01 MOBILE POWER (A59912)
2016 GENERAC...
