2320 to a 2520 ?
/ 2320 to a 2520 ? #1
Jksnvly
Endless Mntns of Pa.
Has anyone here gone from a 2320 to a 2520? I'm contemplating the move. Would like a 3120, but space is an issue for now. What advantages did you gain with the change to the 2520? Thanks for the cont'd assisatance.
/ 2320 to a 2520 ? #2
Lots of posts in the JD threads on this very same subject - I thinks its easier to just search them first - most are recent enough and should pop up
/ 2320 to a 2520 ?
I looked earlier- knew I had seen some in the past- couldn't find any. Lot's on 2305 upsizing though.
/ 2320 to a 2520 ? #4
What is your 2320 is not doing well or can't do that you feel a 2520 / 3120 would do better?
/ 2320 to a 2520 ?
Part of my land has a slope to it. When I use my rotary cutter, there are times she feels a little short on power- I don't know if I 'd feel the slight increase that the 2520 provides- that's why I posed the question. I will also be buying a rear finish or grooming mower and figured that extra HP is beneficial.
/ 2320 to a 2520 ? #6
If your going to make the move . go to a 2520 or jump to a 3320. dont bother with a 3120 it is underpowered for its size. only couple of HP and dragging another 1000 pounds. if you like the size of your tractor. go with a 2520. its just a little bigger than the one you have. and much better hydraulics and more power. it is a more powerful all round tractor than what you had. trust me i drove the one you have. Duc bought a 2320 and traded right up to a 2520 and is very happy . as everyone that has one is. ;)
Thats all i am going to say. or it will start the huge useless debait . and i will just get in trouble. cause i will tell it like it is. and some folks dont want to hear it. so as Duc said. i will let you just do a search on the 2520. and you will see...;) Good Luck.
Chris......:)
