2320 tire psi
/ 2320 tire psi #1
tootallbilly
john deere 2320
I have a 2320 with r4 tires the manual just shows max psi..35 front and 40 rear.I running 25 psi in all tires, but it seems too stiff when mowing I also use a front loader on this tractor.so I dont want to go too low on the front tires.What do you think a good psi would be.....
/ 2320 tire psi #2
R4 tires are very stiff at any pressure. A better seat suspension makes a huge difference.
/ 2320 tire psi #3
Double chck your manual but I would be surprised if you need or want that much in the rear. Not uncommon for the rear to have a lower psi than the front.
/ 2320 tire psi #4
I run significantly lower pressure in the rear versus front. Front's I like to keep about 30psi due to loader work. Rears, 15, 20 max.
/ 2320 tire psi #5
IIRC, I have 25 in the fronts and ~20 in the rears on my 2320. that is the way it came from the dealer. that is too high in the front for non loader work but I do have a loader so it stays. the rear tires squat down a little when I pick up the RFM(~700#) so I am not going lower or higher there.
Lot of (Approx. 30) Venture Lighting 1,250W Metal Halide Bulbs - Fits Allmand Light Towers (A63689)
Lot of (Approx...
21ft Gooseneck Hay/Pine Straw Trailer (A65563)
21ft Gooseneck...
2012 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A63689)
2012 MACK Tender...
2016 Ford Flex SUV (A64557)
2016 Ford Flex SUV...
40in. Skid Steer Tree Spade (A65640)
40in. Skid Steer...
2004 Cadillac Eagle Ultimate Hearse, Eagle Coachbuilders, Hearse Collector Special (A63689)
2004 Cadillac...
