2320 tire psi
/ 2320 tire psi #1
tootallbilly
john deere 2320
I have a 2320 with r4 tires the manual just shows max psi..35 front and 40 rear.I running 25 psi in all tires, but it seems too stiff when mowing I also use a front loader on this tractor.so I dont want to go too low on the front tires.What do you think a good psi would be.....
/ 2320 tire psi #2
R4 tires are very stiff at any pressure. A better seat suspension makes a huge difference.
/ 2320 tire psi #3
Double chck your manual but I would be surprised if you need or want that much in the rear. Not uncommon for the rear to have a lower psi than the front.
/ 2320 tire psi #4
I run significantly lower pressure in the rear versus front. Front's I like to keep about 30psi due to loader work. Rears, 15, 20 max.
/ 2320 tire psi #5
IIRC, I have 25 in the fronts and ~20 in the rears on my 2320. that is the way it came from the dealer. that is too high in the front for non loader work but I do have a loader so it stays. the rear tires squat down a little when I pick up the RFM(~700#) so I am not going lower or higher there.
