2320 Lawn Compaction
/ 2320 Lawn Compaction #1
smalltown
Western Maine
2011, JD 2520
Just wondering if 2320 owners have any issues with lawn compaction?
The move up from a 2305 or the new 1026R to the 2320 gets you about 200 lbs more tractor weight, but at the same time larger tires.
I searched and there is really only on thread about compaction and it did not answer thew question.
/ 2320 Lawn Compaction #4
these tractors weigh alot in most any form..It effected my grass..We have rich black soil dhere in the heartland.
/ 2320 Lawn Compaction #5
I have red clay soil here in NC. Even with a 2520, I have no problem with compaction.
/ 2320 Lawn Compaction #6
I too have clay soil which packs like concrete. I have no compaction with my 2520.
/ 2320 Lawn Compaction #7
Gee I cut 3 acres with a Kubota B3200 with loaded tires and no problem, although I do need to be aware if ground is soaking wet.
DevilDog
/ 2320 Lawn Compaction #9
I got compaction with my 2210..I went zero turn for my yard..
Yep. It's all in the lbs/sq in. A 20,000 lb snowcat with 5' wide tracks exerts less pounds per square inch than a refrigerator.
In the spring or wet weather I get ruts you wouldn't believe. They are not visually apparent BUT say I mow north/south in wet weather, then east/west later boy does it bounce!
I tried for a couple years to smooth the yard with a 48 inch lawn roller weighing over 900 lbs. Unfortunately the 2210, weighing 3/4 of a ton, exerts far more PSI on the ground than the roller, still leaving ruts. Can't win there but the yard is former horse pasture anyway.
/ 2320 Lawn Compaction #10
I searched and there is really only on thread about compaction and it did not answer thew question.[/QUO I think it really depends on your land and the time of the year. Things stay pretty wet around here until mid may. I just sold my 2305 and moved up to a 2520. The 2305 really for the most part was to heavy for mowing my yard however not big enough for my other uses,so I ended up buying a x530 just for mowing, about 700 pounds lighter than the 2305. That would be another alternative, a dedicated mower,just a thought.
/ 2320 Lawn Compaction #11
Then with the Zero turn ya dig up the yard when you turn till you get the hang of it..Nothing is perfect..
/ 2320 Lawn Compaction #12
Even though not purchased yet, I'm no longer worried about a 2320 and compaction. I currently have a LT190 weighing about 550ish pounds and was worried about going to the 2320 with 62D weighing close to 1900 pounds (i think the 1660 pounds for the 2320 is tractor alone? 62D must weigh another 200 pounds?). My neighbors has a JD Z810A and it weighs over 1400 lbs and he has no compaction issues so, surely, the 2320 with even bigger tires should have no compaction issues???
"I think the 1660 pounds for the 2320 is tractor alone? 62D must weigh another 200 pounds?"
Your very close the 62D is listed at 422lbs. That's heavier than I thought! I guess it needs to be beefy if you can drive up over it.
/ 2320 Lawn Compaction #14
I will run my 2520 over the scales sometime and post the results..Just to see whats what..
/ 2320 Lawn Compaction #15
I only have compaction issues in wet soil......other than that no issues.
Caterpillar D6H Series 1 and 2 Dozer Service and Parts Manuals (A63117)
Caterpillar D6H...
2001 Blaw-Knox PF 150 Paving Machine  (A62679)
2001 Blaw-Knox PF...
Generac Generator (A61572)
Generac Generator...
2022 John Deere 612R Sprayer (A63111)
2022 John Deere...
2008 GMC 4x4 Ext. Cab 9Ft Flatbed Pickup Truck (A64194)
2008 GMC 4x4 Ext...
2017 FORD F-350 XL 35' NON-INSULATED BUCKET TRK (A59823)
2017 FORD F-350 XL...
