2320 finally delivered
/ 2320 finally delivered #1
incubus2432
Grafton, Ohio
JD 2320
I ordered a 2320 in mid-December and it was delivered today. The tractor itself, 200cx FEL, 54" bucket, ballast box and 62D MMM were all in within a week or so of the initial order but the brackets needed to mount the FEL were a no show until this morning.
I had originally ordered a 2305 but decided it might be "just enough" so I went a step up. The 2520 was also in the running but I was already over budget and thought the slightly smaller size of the 2320 would suit my needs better. The superior hydraulics of the 2520 were attractive but not enough to convince me to make the leap. I own just under 5.25 acres that is relatively flat and mostly cleared. The main uses of the tractor will be mowing, leveling/remaining clearing/maintaining the property and (eventually) assisting with taking care of our future horse barn. A PHD and box blade are on the Spring shopping list.
I got to break it in a bit this evening with some light snow clearing duties. We have a 300'-ish drive that is flat with a few gradual turns. The FEL worked better than expected and cleaned things up in short order.
It's too early to say for sure but I do believe that I made the right decision. :cool:
/ 2320 finally delivered #2
:cool:
Ready to roll. Nice that you have some snow to move around. :D
/ 2320 finally delivered #3
Great pics. Love the green against the white.
Congrats!
/ 2320 finally delivered #4
Nice! I was looking at th 2320 and ended up going up to the 2520. Let us know how this works out for you.:D
/ 2320 finally delivered #5
incubus2432,
Very nice, you did well. I went from a 1988 JD 650 to the 2320 and have no regrets. I looked at the 2520 and quite honestly the extra money was not the issue, just felt I did not need the so called extras.
/ 2320 finally delivered #7
Nice tractor. Hope they come out with an 1820 by the time I want to trade mine in about 2-4 years. The 3ph settings are an improvement on the 2320 over my 4010.
Ralph
/ 2320 finally delivered #10
Nice rig.
Shiney and new and good for you.!!
/ 2320 finally delivered #11
Very nice! The exact set-up I'm hoping to get. Did you give any consideration to getting turf tires since you'll be mowing with your unit?
/ 2320 finally delivered #12
It really does look good against that "white" background:)
Good luck with your new tractor.:)
Greg
Thanks! The turf tires aren't an option with the loader. The r4's have a higher load capacity so they are "required" when ordering as a package. From most of what I have read the r4's shouldn't be an issue with mowing and my property isn't golf course caliber so I should be OK. :D
BTW......I got the 2320 "stuck" for the first time today (that didn't take long). I insisted on clearing the drive again after a massive 2"-3" snowfall and as I was dumping a bucket full I drove the right front wheel into a drainage ditch causing a two wheel teeter-totter. Cool! The 4wd wasn't able to secure enough traction so I used the FEL to walk it out. Maybe I should load up my ballast box as well. Certainly not a big deal but it made me glad for all of the mishaps I had on a Bobcat years ago at my previous job that taught me some simple, yet valuable, lessons. I'm looking forward to Spring when I can get into some serious work and really test it's abilities.
The hydraulic speed seems sufficient. I know it is an issue when considering the 2320 vs. 2520+ but while the loader isn't what I would call fast it does not seem lazy which would be a problem.
/ 2320 finally delivered #14
Turf tires and loader weren't a problem with my 2520. (2007)
Something new ?
Personally I think the weight of the tractor is a much larger issue.
I haven't used my 3 point yet, though. My BH is on year round.
A 2320 probably would have served my purposes also.
I've moved and dug quite a bit of gravel and rocks, so the buckets don't look shiney new any more. :)
/ 2320 finally delivered #15
Thanks! The turf tires aren't an option with the loader. The r4's have a higher load capacity so they are "required" when ordering as a package.Turf tires and loader weren't a problem with my 2520. (2007)
Something new ?
My dealer asked me which tire I wanted,nothing about a requirement.
Greg
Well then I stand corrected. When I initially placed my order for the 2305 my salesman said that with the loader I had to get the r4's due to the load rating of the turf tires vs. the r4's. That may have just been for the 2305 and I assumed it applied across the board or maybe it is simply my dealer's policy (which may be misinformed or based on solid info). I wasn't too interested in turf tires anyway so it really didn't matter to me. If my dealer gave me incorrect info that's fine as well.......it is up to me to find out all I can and my dealer was wonderful to deal with so if this was an error on their part then so be it. No harm done.
/ 2320 finally delivered #17
incubus2432,
Ok, I am here to say my dealer told me the same thing and like you I would rather have the R4's so I did not care. My dealer also said I would need to purchase a ballast box for the rear if I wanted the loader and no backhoe and this was not an option. Again, it made no difference to me as I was not buying without the backhoe anyway. I bought a ballast box anyway, and I am glad I did.
/ 2320 finally delivered #18
Hello incubus2432,
This is from the manual. I can see why alot of dealers recommend the R4's. There is a huge difference in capacity,especially the rear. I simply went with the R4's because they are 6 ply rating. Going in and out of the woods,I'd rather have the beefier sidewall. I had no idea there was that much of a load difference:)
Tire Loads
NOTE: Maximum load capacity for single tire.
Front (23x8.5-12 R4 6PR) 303 kg (667 lb)
Front (24x8.5-14 R3 4PR) 171 kg (558 lb)
Rear (14-17.5 R4 6PR) 991 kg (2185 lb)
Rear (36x14.00-15 R3 4PR) 535 kg (1179 lb)
Greg
/ 2320 finally delivered #19
I guess each dealers have there own policy, depending on there own experience in the pass. My dealer gave me the choice of tires, but when I bought the fel, the ballast box was included. I'm sure they had it included in the price of the fel, but I had no choices, it was standard with the fel.
Same with the ballast box......it was included in the FEL purchase unless I bought a backhoe. I'd love a backhoe.....just not willing to part with $7k (yet). I would have bought the ballast box anyway so that was no big deal either.
This was my first tractor purchase and although I did plenty of my own research I put some trust in my dealer/salesman as well due to my lack of practical experience. I was quite pleased with their patience for my stupid questions and order changing. I was never "sold" anything.....options were presented and pros/cons laid out. That's the way I prefer my customer/salesperson relationships to be. That's why I said that even if my dealer was wrong in the tire "requirement" I was OK with it. After seeing the load ratings it seems as though there is justification for their policy.
