2320 Electrical Question
/ 2320 Electrical Question #11
Hey just wanted to put in my 2 cents here... I would def. start by cleaning all battery connections and ground wire at frame connection. I think its over the right front tire... Next take the battery to auto store and have it tested, Im betting its shot! I have seen these batteries do some weird things especially on newer "20" series tractors that rely on specific voltages..
The reason your tractor quit when you turned PTO switch on is your actually engaging an electric solenoid to allow hydraulic flow to your PTO clutch.. The extra amperage required to run this probably reduced what juice you have left in battery (thanks to alternator) to the point where the fuel shutoff solenoid (also required specific voltage to operate) clicked out and shut off fuel to engine.
Bottom line is your most likely looking at new battery.. As mentioned above the JD batteries are not the greatest.. Good Luck!!
Thanks. I was not aware of the solenoid allowing hydraulic flow to the PTO clutch. That now makes sense. Also explains why the engine then kept cutting out at high rpms-no juice to the fuel shut-off solenoid.
2007 Jeep Liberty 4x4 SUV (A59231)
2007 Jeep Liberty...
2017 Ford F-550 4x4 Ext. Cab Mason Dump Truck (A59230)
2017 Ford F-550...
2014 Eager Beaver 50SL/3 53ft 60 Ton Tri-Axle RGN Low Boy Trailer (A59230)
2014 Eager Beaver...
KUBOTA SSV65 OPEN STATION CAB (A52706)
KUBOTA SSV65 OPEN...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
2021 MULTIQUIP WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP...
