kernal
Was grading a driveway with the box blade and the 3pt started bouncing. I've done some searching and I think I've lost a seal but wanted to see if anyone here has had a similar issue. 3 pt bounces while running, unless its down. Lift it up and it's dropping and the position control is raising it, at a rapid rate. Adjusting the rate valve has no affect. Closing the rate valve will hold the 3pt, but it will not stay up unless the rate valve is closed. Shutting off the tractor, the 3pt drops right away, only thing I can think is that there is a seal gone in the rock shaft cylinder. No visible leaks anywhere.
Anyone had this happen, I'm guessing this is not going to be a quick fix.
I know it just happened as I took the snowblower off, to grade the drive, and it was holding it a foot off the garage floor.
Maybe it's time to upgrade to a 3 or 4 series.....
Thanks,
Scott
Thanks,
Scott
![20150416_180817[1].jpg 20150416_180817[1].jpg](https://www.tractorbynet.com/forums/data/attachments/386/386608-e191e20577ad2de48ef02ccc33b740f5.jpg)
