Mowing 2310 Mid-Mount Mower Issue
/ 2310 Mid-Mount Mower Issue #1
madhatter
Sherwood Park,Alberta,Canada
2015 Massey GC1710
I noticed lately that when I raise my mower, the one arm lifts and then the other. Same when I lower it. They don't raise at the same time. It never used to be a problem. I only have 40 hours on the machine. Any ideas ?
As well, how high do most you you cut your grass? The is a sticker on the deck ( i have the mulch deck ) that shows the different height adjustment for the deck wheels....
Thanks
/ 2310 Mid-Mount Mower Issue #2
mine raises and lowers that way too...but when it's all the way down for mowing it's level.
I don't remember the setting...but I want to say that sticker showing what number to cut on is wrong...if I were to cut on those settings I'd have knee high grass! :D
I have the wheels all the way down and my deck adjusted so the wheels are barely suspended above the ground.....they are only used for anti-scalping.
/ 2310 Mid-Mount Mower Issue #3
Mine operates the same way. Once it hits the gauge setting it levels out.
/ 2310 Mid-Mount Mower Issue #4
I noticed this on mine also and it seems to have gotten worse as time goes on. I am thinking that the pin that goes through the shaft for the left side is wearing. Since I am out of the mowing business with my tractor, I will prob. not investigate it further.
I could have sworn it used to lift at the same time? But if everyones mower is lifting the same then I guess it is normal ?!
2006 Ford F-350 12ft. Flatbed Truck (A61573)
2006 Ford F-350...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
2021 John Deere 4044M (A64126)
2021 John Deere...
KMC 11 Shank V-Ripper (A64126)
KMC 11 Shank...
2014 CATERPILLAR D5K2 LGP CRAWLER DOZER (A65053)
2014 CATERPILLAR...
2007 Mack CV713 Granite T/A Pole Truck (A62679)
2007 Mack CV713...
