Mowing 2310 Mid-Mount Mower Issue
/ 2310 Mid-Mount Mower Issue #1
madhatter
Sherwood Park,Alberta,Canada
2015 Massey GC1710
I noticed lately that when I raise my mower, the one arm lifts and then the other. Same when I lower it. They don't raise at the same time. It never used to be a problem. I only have 40 hours on the machine. Any ideas ?
As well, how high do most you you cut your grass? The is a sticker on the deck ( i have the mulch deck ) that shows the different height adjustment for the deck wheels....
Thanks
/ 2310 Mid-Mount Mower Issue #2
mine raises and lowers that way too...but when it's all the way down for mowing it's level.
I don't remember the setting...but I want to say that sticker showing what number to cut on is wrong...if I were to cut on those settings I'd have knee high grass! :D
I have the wheels all the way down and my deck adjusted so the wheels are barely suspended above the ground.....they are only used for anti-scalping.
/ 2310 Mid-Mount Mower Issue #3
Mine operates the same way. Once it hits the gauge setting it levels out.
/ 2310 Mid-Mount Mower Issue #4
I noticed this on mine also and it seems to have gotten worse as time goes on. I am thinking that the pin that goes through the shaft for the left side is wearing. Since I am out of the mowing business with my tractor, I will prob. not investigate it further.
I could have sworn it used to lift at the same time? But if everyones mower is lifting the same then I guess it is normal ?!
2018 DRAGON  130BBL VACUUM TRAILER (A65643)
2018 DRAGON...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
New/Unused Landhonor Hydraulic Quick Attach Pallet Forks (A65583)
New/Unused...
Bulk Lot of NEW Motorcycle Control Cables - Motion Pro & Biker's Choice (A63118)
Bulk Lot of NEW...
